Afraid to use hypertech!
Old Jun 2, 2003 | 04:28 PM
KeukaZ71's Avatar
Default Re: Afraid to use hypertech!
i have mine set for +3 +10 +0. bump up that 2-3 shift up to 10 or 11. 3-4 shift you can leave at zero since you will never need it. i tried mine at 93 octane once. no SOTP difference. someday when i have time, i will try using my g-tech to see if there is a difference. i put it back at 87 tuned. gas is way to pricey. not sure how much the tuning helps anyways. i definitely feel it pull harder when the shift points are bumped up though. it enters the rpm range where your truck should really perform and pull hard.
Old Jun 2, 2003 | 04:31 PM
KeukaZ71's Avatar
oh ya, i forgot, you might want to program the rev limiter to a higher value if you plan on increasing the shift points. forgot where i have mine. you should be ok where you are at, but to be on the safe side throw her up to 6000 or even higher
Old Jun 2, 2003 | 05:11 PM
What do u guys mean by all of this +3+10+0 stuff?
Old Jun 3, 2003 | 08:59 AM
TIM02Z71's Avatar
Thanks man. I will try those settings.
Old Jun 3, 2003 | 09:15 AM
graygmc's Avatar
ok here is what happened to me. one day i tried to reprogram my hypertech but couldnt because it said the file was corupt. so i had to send it off to hypertech. they sent me a new one hypertech but now the old settings are permantly on my ECM. so i will have to go up to the dealer and get my ECM flashed back to a stock setting.
Old Jun 3, 2003 | 09:40 AM
bigguy75inches's Avatar
shop around to get your computer reflashed.
i got mine reflashed for only 40 bucks
Old Jun 3, 2003 | 03:47 PM
KeukaZ71's Avatar
+3 means how much you raise your shift point from 1st-2nd gear, +10 is the 2-3 shift, etc... forgot how much each "+" represents. might be like 150 rpm's or something. it is in the owners manual. i haven't programmed mine in a while so i forgot.
Old Jun 3, 2003 | 07:46 PM
TG02Z71's Avatar
Like you said, it means mph which equates to rpm, and that rpm will vary depending on final drive ratio, and tire height. There arre some good formula pages on the net that help you figure the tire height out if you don't know how to figure it from the tire codes.
These are all pretty cool.
http://www.prestage.com/carmath/formulas.asp
http://www.montecarloss.com/SSThunder/formulas.html
http://gs.tolan-hoechst.com/tirecalc.htm
Old Jun 4, 2003 | 12:32 AM
graygmc's Avatar
did you end up gong to a dealer and can you just call them and they will give you a price over the phone? so why did you have to have your ECM flashed?
GRRR65GTO
Aug 17, 2015 11:33 PM
BIGD4504
Jul 28, 2015 11:46 AM
work in progress
Aug 29, 2002 11:36 AM
CashDudeHomie
Jul 13, 2002 06:23 PM
