AC system rebuild, 2001 suburban
Old Oct 12, 2014 | 05:53 AM
RezinTexas's Avatar
Originally Posted by 01silvy
The OEM part is usually the best. Can you find a AC delco replacement compressor?
have you had good experiences with AC Delco comps in the past? I'm willing to try it and spend any amount of $$$. Denso was OE on this truck.
Old Oct 13, 2014 | 08:08 AM
akcooper9's Avatar
This was the compressor I bought when I rebuilt the tahoe's ac system.
Amazon.com: Denso 471-0316 New Compressor with Clutch: Automotive Amazon.com: Denso 471-0316 New Compressor with Clutch: Automotive
It's had two full Texas summers on it now and still going strong.
One thing I make sure to do is get the front blowing cold before kick on the rear and when I first kick on the rear the front is set to 1. Once its all going cold, adjust to your liking.
Also, how are flushing the lines? I used this: http://www.autozone.com/autozone/acc...estid=20056945 along with this
Amazon.com: Mastercool (91046-A) Silver A/C System Flush Kit: Automotive Amazon.com: Mastercool (91046-A) Silver A/C System Flush Kit: Automotive
Another thing. In the rear AC, there is a small screened filter that needs to be cleaned.
Old Oct 16, 2014 | 06:15 PM
RezinTexas's Avatar
Also, how are flushing the lines? I used this: A/C Pro / 1 qt. flush and clean - Not for Hybrid vehicles with electrical driven compressors (CQS-11) | A/C System Cleaner | AutoZone.com along with this Amazon.com: Mastercool (91046-A) Silver A/C System Flush Kit: Automotive
On my first go-around, I used something very similar to flush the lines, and lots of compressed air to dry the lines.
My main concern is knowing how to put how much oil in what places? If I take it to a shop, can they put in the right amount of freon pre-mixed with the oil? Not sure how that works.
Old Oct 17, 2014 | 12:59 PM
akcooper9's Avatar
All I did was drain the compressor before install and fill with the 11oz required. Then took it to the shop for a vac and charge.
Did you clean the screen filter in the rear ac? I missed it the first time I went to have my ac charged and I wasnt getting 'cold cold' air. So the shop evac'd the AC and I went home and swapped out the rear expansion valve and thats when I found the screen filter. I cleaned that as well.
Old Aug 17, 2015 | 04:53 PM
Jcp3sons's Avatar
Registered User
Default 2001 suburban a/c
I just did the same thing except for condenser. It's August and 90 degrees in NC. I am getting same 56-58 at vent. I did find that removing entire Rear a/c cartridge after disconnecting coolant and a/c lines allowed for ease of disassembly and change out of expansion valve.
I bought the R134a Freon at Walmart. They had 12oz bottles for about $7 each. Next, to ensure I got the proper amount of Freon charge (48oz specification), I got a food scale and measured exactly how much from each bottle I put into the system. Of the 5 bottles I bought, 3 were at 12oz, and two were at 10oz of net fluid.
I'm confident that the scale is accurate within +/- 1oz. I tested it with various lead fishing weights in the sports/outdoor section at Walmart.
Here are the gauge pressures after I got 48oz of fluid into the system. This was at around 90-F with high humidity.
The lowest temperature at the vents was a steady 58-F. Considering how hot and humid the weather is right now, I think that is the best I can do. The system now feels like a new OEM system and the performance is excellent. I am extremely pleased with the results.
Thanks for reading, hopefully this helps some of you out there.
Old Aug 19, 2015 | 12:35 PM
akcooper9's Avatar
Just an FYI, one can replace the rear expansion valve with out removing the whole assembly but its no where near as easy!
RT did you ever solve your AC problems?
Old Aug 19, 2015 | 01:24 PM
Atomic's Avatar
I have a gauge for that
Gonna take a look at this later...
Old Aug 19, 2015 | 04:06 PM
Jcp3sons's Avatar
Registered User
I'm calling it "good" at this point. This gas hog sits most all the time until I need to pull camper or haul a posse. I need to get it out and drive it around on a hot day to assess. But it was humid and hot last weekend when we finished and it all seemed good. Very happy with performance to this point.
Old Nov 19, 2016 | 06:48 AM
RezinTexas's Avatar
Hey, sorry for the very late reply. No, I have not fixed the AC system yet. The truck has been sitting in storage for almost 2 years while I'm on assignment in Norway.
I plan to gut the system "again" when I get back to Houston. Hopefully sometime in late 2017 or early 2018.
Kind regards
SLOPONY
20
Oct 18, 2016 06:05 AM
FlowmasterMufflers
Aug 28, 2015 10:58 AM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
rojeho
Aug 8, 2015 07:20 PM
