ABS and Brake light
Old Feb 18, 2005 | 01:05 AM
MrStaggrLee's Avatar
There are 2 ground wires on the side of the frame near the front part of the drivers side door. These ground wires have seperate bolts holding them in place(I believe its a 15mm head). One ground wire is for the ABS module. If corrosion develops at this ground wire the ABS and brake light may illuminate intermediately or constantly. If corrosion develops at the other ground wire the truck may die while driving or not start at all.
Old Feb 18, 2005 | 12:34 PM
Texas Terminator's Avatar
11 Second Club
huh, good info.
Old Feb 19, 2005 | 07:50 AM
The ABS light and the BRAKE light do not follow each other. If the ABS light is ON by itself, the ABS is not operational, but you still have EBD(electronic brake distribution aka proprtioning). If the BRAKE light is ON due to an brake related failure, the ABS light will also be on. In this situation, you have no ABS and no brake proprtioning. My advise is don't drive the car until it is fixed. Driving with no proprtioning or brake bias is dangerous.
Old Feb 19, 2005 | 12:50 PM
11 Second Club
well, you must be a mechanic.........
Old Feb 19, 2005 | 02:40 PM
Default Take It To An ASE Garage
Hey dude, at my garage, we replace alot of ABS Modules!! They go bad alot. The module is under your framerail and has the ABS Pump bolted to it. You may want to get them checked. If the module is bad, then you got no ABS, you just have "old school" brakes. But if the pump is bad, you got problems. Problems that cost $668.00 to fix.
Old Feb 19, 2005 | 07:57 PM
KeukaZ71's Avatar
my ABS light and ebrake light flashes, but my ABS still works though.
actually, i wish it didn't. i hate having ABS in snow
Old Feb 24, 2005 | 06:09 AM
Not a mechanic, I am a software engineer at Bosch Braking. I work on the ABS/TCS/ESP software.
Idryfly5
Sep 2, 2022 08:55 PM
06 4.8
Sep 11, 2015 10:36 AM
MA$TER_E
Sep 9, 2015 03:14 PM
the owl
Sep 4, 2015 04:09 PM
Alco
Sep 4, 2015 04:08 PM
