99-06 UD pulleys
Old Oct 27, 2012 | 02:28 PM
kush killer's Avatar
Default 99-06 UD pulleys
i know the UD pulleys slow down the accs. , would i need to use a OD pulley on the alt. if i want it to spin at normal/faster speed? reason i ask is i have a DC power 270xp alt. and high powered stereo system. so i need it to spin at normal speed if not faster.. ( produces full output 270amps @ 2000rpm)
Old Oct 27, 2012 | 08:59 PM
blueshifty's Avatar
I am running a powerbond UD pulley and an ASP OD alternator pulley. It will run the alternator at the same speed it did stock this way.
Old Oct 27, 2012 | 09:42 PM
cool thats what i was thinking but wasnt sure
Old Oct 31, 2012 | 10:55 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
Although we have many customers run underdrive crankshaft pullies without and od pulley on the alternator, I would suggest running the overdrive alternator pulley anytime you switch to an underdrive crank pulley.
Old Nov 3, 2012 | 11:44 AM
topfueljim's Avatar
Default Underdrive Pulley
Since the whole idea if running an U/D pulley is to reduce the drag from the turning of the water pump, p/s pump, a/c, and the alternator; aren't you losing a large part of the benfit by spinning the alternator back at it's original speed?
Old Nov 3, 2012 | 01:08 PM
Ferocity02's Avatar
You will lose some benefit, but you're also spinning the AC, water pump, and power steering slower.
I did this swap and replaced the stock 105A alternator with a 145A alternator and didn't swap the alternator pulley. I have e-fans and a single 800W sub, no issues so far. The lights don't dim at all even at idle.
If you know the OD of the crank and alternator pulleys, and have the current output vs. speed chart of the alternator, you can easily calculate what power the alternator is outputting.
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
DrX
Sep 29, 2015 04:31 AM
murderedSS
Sep 27, 2015 10:16 PM
