98 vortec 4x4 headers?
Old Dec 31, 2005 | 05:49 PM
1redta's Avatar
Default 98 vortec 4x4 headers?
hey guys I am thinking of putting some long tubes on my extended cab Z-71 I am wondering who makes good quality headers for this truck... it doesn't have cats and I can make a y-pipe to adapt to the flowmaster cat-back. Thanks Art
Old Dec 31, 2005 | 08:00 PM
Tractionless's Avatar
I've heard good things about Doug Thorley headers on these trucks. I dont know if they fit on 4X4s though... Ill look into it and keep you posted.
Here you go:
Doug Thorley midlenght headers for 96-99 5.7 4X4 GM pickups: Part # THY-301Y-FED
Doug Thorley Website LINK (Third ones from top)
Summitracing part # DTE-301Y-FED LINK
Some info: Thorley headers are designed to outflow your stock exhaust manifolds. These headers increase gas mileage and give your engine more horsepower across the entire rpm range. The Tri-Y configuration builds the most power in the middle rpm range, which is great for towing and steep grades. To make these headers last, Thorley made them out of durable 14-gauge mild steel, with 3/8 in. thick flanges and 5/16 in. collector rings. To prevent leaks, these headers have an O-ring welded into the flange, in addition to the high-temperature gasket provided.
There is also THY-301Y-FED-C LINK for ceramic coated.
Hope this helps.
Attached Thumbnails 98 vortec 4x4 headers?-dte-301y-fed.jpg   98 vortec 4x4 headers?-301y_fed.gif
Old Jan 1, 2006 | 06:50 AM
1redta's Avatar
Default re
Thanks for the good info man I really appreciate it
Old Jan 1, 2006 | 12:57 PM
chadjcompton
17
Jun 21, 2022 08:47 PM
ARC
57
Feb 21, 2022 10:54 AM
2500ZL1
Jan 25, 2016 06:30 AM
stealthperf
Sep 18, 2015 05:51 PM
4B11T
Jul 13, 2015 03:48 PM
