98-02 Camaro Electric Fans on 03 Silverado
Old Oct 29, 2003 | 02:44 PM
12 Second Club
Question 98-02 Camaro Electric Fans on 03 Silverado
Any Help would be appreciated!
I have a 2003 Silverado and would like to know if 98-02 Camaro Electric fans will fit on my truck so I can get rid of my power robbing clutch fan. The truck will only be used for street driving/ No off-roading or towing involved. And if they will work, What will I need to complete the installation. The Camaro fans measurements are 28.5 x 18.5 x 5. And if anyone else has done this mod on their truck, how do they like it and is it worth it?
Thanks for any help or advice, you can give!!!!!!!
Bob Jr.
Old Oct 29, 2003 | 02:53 PM
1TRUESS's Avatar
Yes it will work! You will need to make some brackets and get a fan controller. I am using the Flex-a-lite VSC. It works great!
Here are some pics of my setup. Click Here
Old Oct 29, 2003 | 02:59 PM
Buckwheat's Avatar
Ya know, I was thinking the same thing when I had my head under the hood the recently. I have a 00' Z28 and I think it would be very easy...you just need a way to trigger the fans. That might even free up enough room for a "straight shot" type filter system. I'll have looksee at it. Probably free up about 5-10 ponies.
Old Oct 29, 2003 | 03:04 PM
Buckwheat's Avatar
02Silverado answered the riddle while I was typing. Thats a killer setup!
Old Oct 29, 2003 | 04:46 PM
multmigs's Avatar
is there any dyno proof of the payoff in HP and what is that black box that seems to be running the fans hooked up to? Any idea what this cost?
Old Oct 29, 2003 | 05:07 PM
Hit Man X's Avatar
I think ~6rwhp over a NON locked up clutch. Far greater over a locked up one. Throttle response is way better too
Old Oct 29, 2003 | 06:02 PM
agreif's Avatar
Man, nice documentation you got there, keep that up for three weeks so I can have that handy when I put mine in. Question for ya....when you notched that small angle iron, that was so the fan shroud would sit right where you want it? And then the only thing that you have securing the assembly is the ties through the holed in the shroud and through the holes drilled in the angle iron?
Thanks,
Andrew
Old Oct 29, 2003 | 06:21 PM
1TRUESS's Avatar
I notched the angle stock of aluminum so it would bolt to the existing fan shroud bolt holes. I didn't want it to angles out and so it would sit flush with the efans. Ties are holding the efans to the brackets and the bottom of the brackets to the lower radiator support (I think that is what it is called). I used the fan shroud bolts for the top. If any of that make sense. I was going to us all stainless steel bolt, but I used the zip ties to test fit everything and they seen to be working out fine.
Old Oct 29, 2003 | 08:14 PM
slow4.8's Avatar
well what I did was took a mustang GT fan and cut off the brackets and mounted it inside my stock fan shroud. then I wired it up to a relay and put a switch inside the truck and alt. power loss is only marginal.
Old Oct 29, 2003 | 08:46 PM
12 Second Club
02 Silverado,
Thanks for the advice and documentation, it will be a big help when I do the electric fan mod on my silverado. If anyone else has any suggestions on the electric fan subject, I would appreciate it. Thanks
