93 Suburban Questions
I have a 93 Suburban...I start it up in the morning, and when i take off, it hesitates, then it runs fine for the rest of the day....Could it be the injectors? Also, what type of plugs and wires are recommended?? I have the 454...what else would make it run nice? it has about 127000 miles on it...any input would be appreciated, thx
This truck is TBI right? If it is running like *** try some of these:
Fuel Filter (betcha it hasn't been swapped in a while!)
Spark Plugs, Wires
Air Filter
PCV
Check the HEI module and coil too. A good injector cleaning will set you back around $100-150, not that "pour in the gas tank" crap.
Worse case scenario, get a Haynes manual for the truck and run the OBD-I tests on the computer.
Spark Plugs, Wires
Air Filter
PCV
