93 Suburban Questions
Old Jul 10, 2003 | 09:05 PM
Default 93 Suburban Questions
I have a 93 Suburban...I start it up in the morning, and when i take off, it hesitates, then it runs fine for the rest of the day....Could it be the injectors? Also, what type of plugs and wires are recommended?? I have the 454...what else would make it run nice? it has about 127000 miles on it...any input would be appreciated, thx
Old Jul 11, 2003 | 10:46 AM
Hit Man X's Avatar
Default Re: 93 Suburban Questions
This truck is TBI right? If it is running like *** try some of these:
Fuel Filter (betcha it hasn't been swapped in a while!)
Spark Plugs, Wires
Air Filter
PCV
Check the HEI module and coil too. A good injector cleaning will set you back around $100-150, not that "pour in the gas tank" crap.
Worse case scenario, get a Haynes manual for the truck and run the OBD-I tests on the computer.
blownss27
Aug 14, 2020 08:27 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
Tigger Welder
Sep 2, 2015 08:17 AM
USMCvet0311
Aug 1, 2015 07:45 AM
