90mm fast intake.
Old May 15, 2005 | 07:20 AM
Faze2183's Avatar
how do you get the ssr to bolt up to the other manny???
Old May 15, 2005 | 09:20 PM
2bseen's Avatar
11 Second Truck Club
Big Tex did you build the idler pulley? If so did you make a pattern of it, and what year car water pump has the bolt on pulley. Do you have a pic of the alt. bracket. Thanks
Old May 16, 2005 | 08:36 AM
cablebandit's Avatar
9 Second Club
he said "press" the water pulley off. a 98 f-body does have a bolt on pulley. Did you already get the fast intake?
Old May 16, 2005 | 09:23 AM
TigerFan187's Avatar
FAST TB's are cable type they dont have a electronic one out yet. I like that SSR TB!
Old May 16, 2005 | 04:04 PM
2bseen's Avatar
Yes I already have a intake and going to order a ssr t.b. I just want to have everything I need to install so my truck isn't down long.
Old May 17, 2005 | 10:24 PM
BigTex's Avatar
The bracket is basically triangular, but its a little oblong to cover 3 bolts. You can tell the 3 bolt holes it uses to get secured to the alternator bracket. I don't have a template, sorry. I just sold the whole setup to redaddiction for use on his truck. Maybe he can take a picture of the alt pulley before it gets all bolted back on. I think the waterpump is a 97 vette.
Old May 17, 2005 | 11:18 PM
redaddiction's Avatar
I'll get lots of pics when I get the truck back but I'm going out of town in two weeks and not sure when it will be done.
Old May 24, 2005 | 11:19 PM
2bseen's Avatar
How much does the fbody water pump have to be spaced to work? I was thinking I might have some made since I can't find any of the bolt on ones.
Old May 25, 2005 | 06:42 PM
IslandTahoe's Avatar
Big Tex -
On that relocated idler pulley, how is the pulley attached to the bracket? Is it simply bolted thru or is the pulley assembly somehow welded to the bracket? Seems as though I see a little bit if a welding bead showing under the pulley so I was wondering.
Thanks
PS - what thickness on that plate? 1/4" maybe 3/8"? Aluminum? Got to get home and look at this.
Old May 25, 2005 | 06:47 PM
As for the water pump, if you get a mezz e-pump, the belt rides all the way on the edge, but secure on the pulley. This pump comes with the outlet pointing forward.
