90mm fast intake.
Big Tex did you build the idler pulley? If so did you make a pattern of it, and what year car water pump has the bolt on pulley. Do you have a pic of the alt. bracket. Thanks
Originally Posted by BigTex
The bracket is basically triangular, but its a little oblong to cover 3 bolts. You can tell the 3 bolt holes it uses to get secured to the alternator bracket. I don't have a template, sorry. I just sold the whole setup to redaddiction for use on his truck. Maybe he can take a picture of the alt pulley before it gets all bolted back on. I think the waterpump is a 97 vette.
Big Tex -
On that relocated idler pulley, how is the pulley attached to the bracket? Is it simply bolted thru or is the pulley assembly somehow welded to the bracket? Seems as though I see a little bit if a welding bead showing under the pulley so I was wondering.
Thanks
PS - what thickness on that plate? 1/4" maybe 3/8"? Aluminum? Got to get home and look at this.
Thanks
