8.1 swap
Old Aug 27, 2009 | 12:51 AM
04herod's Avatar
Default 8.1 swap
any help full info on this b4 i start
Old Aug 27, 2009 | 12:52 AM
04herod's Avatar
wantin to put it n a rcsb 2000 4.8 truck
Old Aug 27, 2009 | 11:46 AM
nightrunner's Avatar
Mr. Obvious
not going to find a whole lot of help here because the 8.1L doesnt have anywhere near the aftermarket support that the LSx engines have. and you can get more power out of a built 6.0 than the 8.1 or you could probably even boost the 4.8 and get the same power.
its not an easy swap by any means
Old Aug 27, 2009 | 04:00 PM
tank454's Avatar
I would personally go with a 6.0 over the 8.1. Despite what my buddies say, displacement isn't always the way to go.
Old Aug 27, 2009 | 04:22 PM
Mr. Obvious
it is true that there is no replacement for displacement IF technology is equal. in this place there is no comparison.
Old Aug 27, 2009 | 07:13 PM
Whippled 496's Avatar
The poor 8.1L getting kicked around like a red headed step child.....
I agree though.....way more support and easier swap just to go with a 6.0L.
Old Aug 28, 2009 | 04:41 PM
04herod's Avatar
thanx
Old Aug 28, 2009 | 05:04 PM
Mr. Obvious
if you already have it, the marine guys use them alot in boats. but if you havent get a 6.0L truck engine and swap in.
there is a thread on here somewhere about what it takes to swap one in as everyone on here would love to have a twin turbo'd built 496 in their truck.
best i remember on a 1/2 ton truck, basically the entire front half of the frame would need to be replaced with the one from a 3/4ton or 1 ton HD truck. and there was some other stuff but that was the most obvious and labor intensive
Old Aug 28, 2009 | 08:52 PM
L7 Sierra's Avatar
I heard it bolts right in if you use the 4L80, but an allison is completely out of the picture due its emense size on a 1500. A good loose convertor can make up for some of the problems of not having a 6-speed, and it works with your factory computer.
Or if you still want big cubes you can poke and stroke a 6.0 to over 408ci and a 6.2 to over 418 ci. But the engine will not last much past 100,000 miles becouse of the short piston design. I think the 6.2 can get to 434 easily, but longetivey will not be there even if you baby it. I would do the 408-418 combo becouse its the easiest, and life is not terrabley bad if you want big CI's.
Old Aug 28, 2009 | 11:28 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
heres a pic to drool over its a 8.1 in a RCSB my favorite truck by far
