6.2 swap
Old Jan 2, 2011 | 05:53 PM
Chevrolay1's Avatar
Default 6.2 swap
Whats guys need sum help is it worth putting a 6.2 in a 2004 silverado?
Old Jan 2, 2011 | 06:15 PM
skeet's Avatar
anything with more displacement is a good thing if youre going NA but there will be needed parts to complete the conversion
Coban's Avatar
Personally, I would look for an LQ9 and put 243 heads on it if I was looking for a larger engine in a GMT800.
The extra cost of the engine itself and the numerous conversion harnesses doesn't make it work it.
iamkeniff's Avatar
same thing i told you on gmfullsize man. its not that hard, and i gave you a link of exactly what to do.
Old Jan 2, 2011 | 06:17 PM
iamkeniff's Avatar
just a 58x to 24x conversion module, extend the knock sensor harness, and a DR.X 90mm conversion harness. i think if i remember correctly...he already has the short block.
Old Jan 2, 2011 | 06:20 PM
Chevrolay1's Avatar
Yeah ur right can u give me the link agaian im bout to change the reluctor wheel this weekend comming up but im having trouble finding a shop to do it
Old Jan 2, 2011 | 06:21 PM
skeet's Avatar
^^^ he knows ^^^
Chevrolay1's Avatar
Yeah true hows ur build going bro?
Old Jan 2, 2011 | 06:22 PM
Using the 58X to 24X module let you not have to mess with changing the reluctor wheel on the crank. Extend the harness' yourself and save the expense of buying adaptor harness'
Old Jan 2, 2011 | 06:23 PM
Chevrolay1's Avatar
Ok wanna change the reluctor wheel completly wit a 24x
