6.0L Dipstick tube removal ?????
10 Second Moderator
Thanks, penetrating oil didnt help and the rusty spot in the tube about halfway down the tube didnt help either. Its lower half is still in there and the upper half is now out in the field. Damn damn damn...
hah, sure u didnt weld it to the starter like my dad almost did in my 4.8 today? I'd recommend disconnecting the battery. Mine had a drop of oil on the end touch the starter and a cloud of smoke shot in my face, then we disconnected the battery, haha, we were lucky
Sounds like my first one. Now that its destroyed. Option 2. I had to put a set of vice grips with a slide hammer attached and pull it out.
10 Second Moderator
The area around the tube looked like this was a saltbath test block for GM. Rusty bit$h. Slide hammer didnt work either, I needed to bring out the big guns. I cut the tube down to about 1/4 inch then I took a 12" long wood screw that fit the hole pretty good and took my mig welder and welded the screw in the remaining chunk of the tube. Clamped the visegrips onto the welded area and the block gave up the fight and let the tube go. Here are some pictures...
