6.0 underrated? dyno results.
Old Aug 14, 2004 | 03:09 PM
FirstGen's Avatar
Default 6.0 underrated? dyno results.
Just FYI for you board members. Here is what I have.
Dyno results yesterday:
379.42 RWHP
395.3 RWTQ
Stock 2003 LQ4 6.0l
milled heads .030 and reassmbled with new stock GM gaskets and head bolts
C5 manifolds into 2.5 Y-pipe and 3" single ehaust with a huge (quite) Magniflow RV series muffler.
Stock intake, TB, and MAF (descreened)
'01 LS6 cam/springs
LS1 electric fans
ASP underdrive pully
little bitty K&N filter (3" compared to the 4" MAF inlet)
custom wiring harness to fit my truck (1968 C10)
F-body PCM
NO EGR crap
Aeromotive fuel pump and regulator
stock injectors and rails
T56 tranny
12 Bolt with posi and 3.42 gears
Running 295.50R15's
Old Aug 14, 2004 | 03:17 PM
F8L Z71's Avatar
Sounds a bit high. You say this was transplanted into a different vehicle? Also what cam is in there?
Old Aug 14, 2004 | 03:26 PM
XLR8NSS's Avatar
Adkoonerstrator
That's threw a T56 also which will show higher dyno numbers. Still seems a bit high, I think in the trucks the 6.0Ls dyno in the 290rwhp range.
Old Aug 14, 2004 | 03:34 PM
Mr. Sandog's Avatar
Wow.
Stock LQ4 = 325 HP x ~17% drivetrain loss (auto) = ~270 RWHP
Stock LQ4 = 325 HP x ~12% drivetrain loss (man) = ~286 RWHP
You report ~380 RWHP
So you got ~100+ RWHP from those mods, that's amazing.
EDIT: Corrected numbers for LQ4
Old Aug 14, 2004 | 04:13 PM
FirstGen's Avatar
oops sorry 2001 LS6 cam/springs and LS1 fans.
The numbers are great. Hence the title "underated?".
Motor is in a 68 chevy pu.
Might seem high but it's still a fact
I've hear my numbers are low, but, stock I saw 222rwhp. with the whipple and a bad, bad tune I only saw 290.
Old Aug 14, 2004 | 05:09 PM
Originally Posted by Naked AV
Wow.
Stock LQ4 = 345 HP x ~17% drivetrain loss (auto) = ~285 RWHP
Stock LQ4 = 345 HP x ~12% drivetrain loss (man) = ~305 RWHP
So you got ~80 RWHP from those mods, that's amazing.
Stock LQ4 = 320hp
Stock LQ9 = 345hp
Old Aug 14, 2004 | 05:15 PM
F8L Z71's Avatar
Cam and Manual tranz really help out though. Not unbelievable though.
Old Aug 14, 2004 | 06:19 PM
Mr. Sandog's Avatar
Originally Posted by jimbo95z28
Stock LQ4 = 320hp
Stock LQ9 = 345hp
Actually, I think we're both wrong....the LQ4 has 325 HP at the flywheel. Doh! But you are correct, it's the LQ9 that has 345.
Old Aug 14, 2004 | 06:21 PM
XLR8NSS's Avatar
Adkoonerstrator
