6.0 swap questions.......
Old Nov 6, 2005 | 10:10 PM
67SS509's Avatar
10 Second Truck Club
Click on link-LQ9 & LQ4 piston side by side.. http://www.ncez.net/palfam/tapp/rods2.jpg
Old Nov 6, 2005 | 10:42 PM
treyZ28's Avatar
uhh... how is your valvetrain geometry NOT off?
you corrected it with shorter pushrods (which also constitutes more than "slapping them back on"). you slim .30 off the heads and the intake ports will sit .30 higher than what they were. maybe not a huge deal, but still off. sounds like poor way of doing imo.
I wonder the cost difference between a set of KB pistons for a 6.0 and milling, head gaskets and new pushrods.
new pistons will be around $200 + balance.
i haven't priced pushrods, head gaskets and machine work lately.
another question: I know the piston at TDC is above the deck on the block. how much further can it go before contact?
Old Nov 6, 2005 | 10:57 PM
99Silver6.0's Avatar
It is off man. But you fix that by using shorter pushrods. Dam. If you would look around this site, you will see that ALOT of people mill heads and .030 is a safe mill. It is not wrong and I am not the only one who has dont it! I dont understand your view, and Im sorry I dont. So are you telling me. That every person that has heads milled on an LS1.. Their engine is gonna blow up?
Old Nov 6, 2005 | 11:01 PM
treyZ28's Avatar
whats not to get. if you "just slap the heads back on" its off. if you get new pushrods that are shorter, you correct the incorrect geometry.
you didn't mention anything about correcting it, so i mentioned that. Still confused?
milling heads isn't something new, i've had 2 engines with the heads milled.
Old Nov 6, 2005 | 11:04 PM
No. What is wrong with you???? It is perfectly safe to mill heads, jesus.
Scroll back up to my post 10. Read where it says I used shorter rods...
Old Nov 6, 2005 | 11:07 PM
Explain to me how the intake ports will sit higher if you remove material from the head? If you cut the head, the ports sit LOWER.
Deals like this is EXACTLLY why Comp makes a pushrod length checker.
Also.... What is .30?
Old Nov 6, 2005 | 11:30 PM
treyZ28's Avatar
0.030, sorry.
the intake ports;
there are two ends. one on the INTAKE and one on the HEADS.
Old Nov 6, 2005 | 11:31 PM
treyZ28's Avatar
who said it wasn't? why the **** are you so argumentative. i said your geometry will be off if you only "slap the heads back on." Other compesations must be made (pushrods) in order to correct this offset.
I'm not saying it again.
Old Nov 6, 2005 | 11:43 PM
I did pushrods. Why the **** are you so stupid? Put your glasses on and read my post. None of this **** would have trailed on if you would have read my entire post. Its right up there, post 10 in little black letters for you to read.
Ports on the heads will not sit higher if you mill them, im sorry.
Old Nov 6, 2005 | 11:45 PM
Reedy,
Buy the Q9 if you can get a good deal. If not you can always find an LQ4 to toy with. They are everywhere. Be ready to fix the tranny next cause it wont like the new motor.
