6.0 Pushrod Talk!
Old Jun 17, 2005 | 09:07 PM
rob3379's Avatar
Default 6.0 Pushrod Talk!
Hey guys I need to know if stock pushrods will be ok for my application. I have a 6.0 with a XR275HR Comp cam and 26918 Comp springs. I'm running stock heads with a 3 angle valve job and milled .40.
If I need pushrods what length?
Thanks,
Rob
Old Jun 17, 2005 | 09:12 PM
FILE's Avatar
How high will you be revving your engine? I would get them if you were to shift above 6200 rpm. Just a little insurance policy and they don't really cost much.
Old Jun 17, 2005 | 09:16 PM
rob3379's Avatar
I think 6600 or 6800 not sure. I really need to know then if the stock length will work since I milled the heads 40.
Old Jun 17, 2005 | 10:33 PM
Stroker 1500's Avatar
From what i have read you will need a shorter pushrod if the heads are milled. But im building my engine right now and getting the block decked 030 and my builder told me we might not need new pushrods but where going to check. So what i would do is put a stock pushrod in and check to see if it is the proper length, if it is then order some stock length ones that are hardened, If not then get a pushrod measuring tool and find the size you need and order them.
Old Jun 17, 2005 | 11:12 PM
02sierraz71_5.3's Avatar
only way to be shore is to by a pushrod length checker, they are cheap and worth the money, I'll milled my heads .050 and am using stock length rods on a 5.3, was using .050 shorter and the valvetrain was super noisy so went back to stock length and havent had a problem, if i did it over again i would invest in a checker
Meziked-z71's Avatar
.566/.568 lift...
1.7 rocker?
stock replacement springs
Head milled .40...
I wouldnt buy them intill I measured.... you might not need them on a hydrolic setup.. Id guess a 7.35 but that is a guess.. Im probably wrong
7.4" is stock on a LS1 3rd Gen. BTW
Old Jun 17, 2005 | 11:21 PM
another thing the lifters have .120 play in them thats how im gettin away with stock length
Old Jun 18, 2005 | 12:35 AM
gonzo 6.2's Avatar
I hope you are using late Z06 spring for your replacements
Old Jun 18, 2005 | 01:19 AM
99Silver6.0's Avatar
Get a Comp length checker. Its cheap. Or find a cylinder head guy good at math!
SS94S10
Jan 3, 2019 01:57 PM
legerwn
56
Nov 15, 2015 10:21 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
chvy=power
Sep 8, 2015 11:06 AM
