6.0 pistons, which ones for 10.5:1???
Old Oct 14, 2004 | 11:10 PM
99Silver6.0's Avatar
Default 6.0 pistons, which ones for 10.5:1???
Is it possible to attain a 10.5:1 compression ratio in an LQ4 with pistons alone? Or is head work needed also. I think the stock piston/rod specs are like 4" stroke, 3.62" bore and 6.095" rod lentgh. Is that correct? Ive been looking at Diamond slugs but dont know which to look for.
Old Oct 15, 2004 | 09:47 PM
Holy ****!! 11 views and no replies? What kind of board is this? What do I need to add to my post to get a reply?
Old Oct 15, 2004 | 09:49 PM
Sport Side's Avatar
boobies
Old Oct 15, 2004 | 09:51 PM
Sport Side's Avatar
Yes, your numbers are correct on a 6.0L bottom end.
I'm confused on your other questions...
Old Oct 15, 2004 | 10:17 PM
Original question is in my original post.... "Is it possible to attain a 10.5:1 compression ratio in an LQ4 with pistons alone?"
Old Oct 15, 2004 | 11:16 PM
Andy1's Avatar
Jared,
I'd suggest you talk directly with the folks at Diamond for a technically correct answer. BTW, the 6.0 bore is 4.00", and stroke is 3.62...you had it reversed in your post. Rod length is correct.
Andy
Old Oct 15, 2004 | 11:29 PM
Originally Posted by Andy1
Jared,
Andy
I may have to do that. I didnt realize I had the specs crossed.
Old Oct 16, 2004 | 12:04 AM
i think you can run close to 10.5 to 1 if you use an Lq9 piston and mill the heads
Old Oct 16, 2004 | 12:12 AM
BigTex's Avatar
... and run a thinner head gasket.
Old Oct 16, 2004 | 09:15 PM
diamondd2's Avatar
I might be wrong , but I believe the only difference between the LQ4 & LQ9 are the pistons. The LQ4 uses dished pistons and the LQ9 uses flat top pistons.
=Dave
