6.0 pistons, which ones for 10.5:1???
Is it possible to attain a 10.5:1 compression ratio in an LQ4 with pistons alone? Or is head work needed also. I think the stock piston/rod specs are like 4" stroke, 3.62" bore and 6.095" rod lentgh. Is that correct? Ive been looking at Diamond slugs but dont know which to look for.
Originally Posted by SportSide 5.3
Yes, your numbers are correct on a 6.0L bottom end.
I'm confused on your other questions...
Jared,
I'd suggest you talk directly with the folks at Diamond for a technically correct answer. BTW, the 6.0 bore is 4.00", and stroke is 3.62...you had it reversed in your post. Rod length is correct.
Andy
Andy
Originally Posted by Andy1
Jared,
Andy
Andy
