6.0 oil cooler - the opening is there, but not the cooler
Old May 13, 2006 | 01:49 PM
Colby 04's Avatar
Default 6.0 oil cooler - the opening is there, but not the cooler
I noticed on the 6.0, it has a place above the oil filter that looks like an oil cooler was on this engine - but it didn't come with it. Will I have to go to the dealer to get that piece that's missing before I can attach a cooler?
Old May 13, 2006 | 01:55 PM
04BlackSilverado's Avatar
Do you have a 34" radiator with the Driver's side oil cooler in it? Because if you do then you can get the new block with the lines that should bolt up like the factory setup, I just don't know the PN and the dealers around here can't help me.
Can you get the Part Numbers please?
Old May 13, 2006 | 05:31 PM
Colby 04's Avatar
I don't have the 34" radiator. It's a 2004 truck, the engine is from a 2005. Is the "block" the piece that bolts up to that opening?
Old May 13, 2006 | 05:51 PM
99Silver6.0's Avatar
Yes thats where it goes.
Old May 13, 2006 | 09:21 PM
That piece is on all LSx engines. If you want an oil cooler just remove it and install the cooler lines plus a new radiator.
Old May 13, 2006 | 10:00 PM
Ross @ EDO's Avatar
FormerVendor
I just used the block-off plate from my 4.8L when I did my swap.
Old May 14, 2006 | 12:03 AM
Colby 04's Avatar
I may do that for the time being. I'm not sure that an oil cooler will be neccesary for my setup?
Old May 14, 2006 | 12:56 AM
KySilverado's Avatar
Block it off. No need. Its there for the HD truck pulling heavy loads.
Old May 14, 2006 | 03:40 AM
thunder550's Avatar
High on diesel fumes
Weird, mine came with the lines, although they were not attached to the motor on the crate, just laying next to it. I have a 34" radiator too, so I guess I got lucky
Old May 14, 2006 | 07:52 AM
Colby 04 you have a PM
5.3Okasai
Mar 9, 2022 01:07 PM
ullose272
11
Jul 17, 2015 07:22 AM
ferrellrooster
Jul 17, 2015 07:07 AM
GM1697
Jul 9, 2015 01:55 PM
