6.0 oil cooler - the opening is there, but not the cooler
I noticed on the 6.0, it has a place above the oil filter that looks like an oil cooler was on this engine - but it didn't come with it. Will I have to go to the dealer to get that piece that's missing before I can attach a cooler?
Do you have a 34" radiator with the Driver's side oil cooler in it? Because if you do then you can get the new block with the lines that should bolt up like the factory setup, I just don't know the PN and the dealers around here can't help me.
Can you get the Part Numbers please?
Originally Posted by 02White6.0
I just used the block-off plate from my 4.8L when I did my swap.
I may do that for the time being. I'm not sure that an oil cooler will be neccesary for my setup?
ullose272
11
Jul 17, 2015 07:22 AM
ferrellrooster
Jul 17, 2015 07:07 AM
