6.0 is built pics inside
Old Jan 29, 2006 | 01:55 PM
  #31
Dark Halo's Avatar
Originally Posted by BenKey
Wow, great looking engine! Is the block powdercoated? I almost had that done, but it would have taken too long.
Where my motor was built (W, FL area), the standard way to treat motors that are new is to run with just a 30 weight oil for break in - no detergents. Then at 100 miles change to a 10W-30 oil and change again at 500 miles. Once you have the 10W30 oil in you can get on it WOT, just not from a dead stop. Once you have changed the oil at the 500 mile mark, then you can do whatever you want. Do not change to synthetics until 3000 mile mark.
Just about every builder I spoke with over the phone had the same plan.
no I used the VHT paint and cleared it.
Old Jan 29, 2006 | 02:32 PM
  #32
Noticed you went with the LS6 cover. I did the same. Did you plumb in a PCV valve? If so, which way did you do it? I used the LS1howto site, but have heard of doing it differently.
Old Jan 29, 2006 | 02:33 PM
  #33
Cool. Looks powder coated.
Old Jan 29, 2006 | 10:50 PM
  #34
Dark Halo's Avatar
not yet but I plan to use the same how to you did.
Old Jan 29, 2006 | 10:58 PM
  #35
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
whats the worse that can happen I blow it up and build a stroker
I skipped that step and went straight to the stroker
Old Jan 29, 2006 | 11:40 PM
  #36
Dark Halo's Avatar
well I am wanting a 427 stroker and the ls7 or c5r block my be my only options
Old Jan 30, 2006 | 12:35 PM
  #37
stone150's Avatar
that thing is awsome
Oobray
Jun 13, 2022 03:38 AM
chacho44
Aug 17, 2015 03:36 AM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
