6.0 Buildup - Your advice wanted.
Old Sep 24, 2010 | 07:52 AM
  #341
GMCtrk's Avatar
Glad you got things in better order.
BTW, it will feel slow eventually....
Old Sep 24, 2010 | 09:26 AM
  #342
blsnelling's Avatar
I'm selling some of the stuff I don't need after this build. I've put an add in the classifieds. Trailblazer TC, 4.00 tapered riing compressor, adjustable PR measuring tool, 11mm head bolt thread cleaner. I'll be selling the Comp Cams 212/218 cam out of the 5.3 as soon as I get it pulled.
LINK
Old Sep 24, 2010 | 11:03 AM
  #343
blsnelling's Avatar
Here's the intake reducer. Works much better than black duct tape
Now, one last modification is needed. The stud on the throttle for the cruise control cable is larger than OEM. Should I just grind the OD of the stub?
Old Sep 24, 2010 | 03:44 PM
  #344
bgray's Avatar
TOTM: June 2007
Grind carefully My friend. Bit by bit. If the shaft diameter is the same but jsut the nub is to big then you'll be golden
Old Sep 24, 2010 | 10:13 PM
  #345
Kenskip1's Avatar
Registered User
Default Selling a used cam ?
Anybody that knows anything about cams may laugh at this.Especially if the lifters are not matched with the cam lobes, Ken
Old Sep 24, 2010 | 10:42 PM
  #346
blsnelling's Avatar
I think you're stuck in the SBC world of flat tappets. It's done all the time with LS engines, since they're roller cams.
Old Sep 24, 2010 | 11:28 PM
  #347
Kenskip1's Avatar
Registered User
Default Used cams
Brad, yes I am a dinosaur.I was brought up with mid 70's Chevy, I installed a 400 small block into a 67 El Camino, had the dished pistons removed and installed speed pro flat tops.I installed a big block oil pump, along wit an eledbrock cam and intake, topped off with a 650 spread bore. 1.58 headers. I am an old school but I did not mean to rain on your charcoal.Ken
Old Sep 24, 2010 | 11:33 PM
  #348
blsnelling's Avatar
It's all good. This is my first time this deep in a LS engine. I'm 42 years old myself. They're different for sure, superior to the old SBC in so many ways.
Old Sep 29, 2010 | 09:04 AM
  #349
blsnelling's Avatar
Originally Posted by GMCtrk
Buy EFI live V1 (no need for v2) and I'll get you set up. Your engine setup is very similar to mine.
I'm about ready to take you up on this offer My v2 should be here any day now. I'm excited to start getting this tune sorted out.
Where can I go to find out how to get started, ie getting connected, pulling the bin from my PCM, editing the tables, etc.
Old Sep 29, 2010 | 11:58 PM
  #350
bgray's Avatar
TOTM: June 2007
I also talked to justin and kbracing and i will be buying efi live also.....just alot nicer being able to make changes without waiting fornthem to redo things
