6.0 Build-Need a question answered please.
Old Dec 5, 2007 | 08:56 PM
Turbojunkie's Avatar
Default 6.0 Build-Need a question answered please.
Hello to all. I have been searching and reading for a little bit to try and figure some things out. I know there is a difference between the lq4 and the lq9. I also understand that the lq4 had a different crank in early 2000 therefore not allowing a T56 to bolt up.
SO HERE IS MY QUESTION- I have a chance to get an early style lq4 and I was wondering if I was to change the crank (forged bottom end setup) WOULD I be able to mate a t56 to this block/crank setup. I am just making sure that since the early 2000ish cranks WERE different, the block would still work if I was to build the bottom end like I was building for an older LQ4. Thank you guys/gals.
Clark
Old Dec 5, 2007 | 09:50 PM
Tootall's Avatar
the longer cranks were the 99-00
Old Dec 6, 2007 | 05:01 AM
ok. But if I was to swap the crank for a forged bottom end from a new series which would allow a t56, would that work?
Old Dec 6, 2007 | 08:09 AM
Tootall's Avatar
yes it would. There's no need for a stock stroke, forged crank. There are guys on here that are making 500-600 on the stock crank.
Now if you're wanting a stroker crank then do that.
If you're looking for some comparisons, there plenty of guys that are running stroked 6.0 (408s) with a t56 behind them on LS1tech
ferrellrooster
Mar 6, 2025 03:22 PM
Abuckeye
Aug 19, 2015 06:11 PM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Hmguyton
Jul 7, 2015 03:29 PM
