i have a question about e-fans
Old Dec 4, 2007 | 05:59 PM
04bluesilverado's Avatar
Question i have a question about e-fans
I have the nelson performance harness and 05 efans for my truck. Whats the best way to push the wire through #42 and also when connecting the wire to the ac wire i believe, which green wire is it? the light green or dark green.??
Old Dec 5, 2007 | 10:28 PM
colekill's Avatar
KickinAssAndTakinNames
the pin is a bitch. i took a piece of stiff wire and pushed it through to loosen it up then some small needle nose to pull the pin in. just do it the best you can. on my 99 i tapped the dark green the other option was a a green wire with a white stripe on it. make sure its the right wire for you if not you might **** something up, like i did.
good luck
Old Dec 5, 2007 | 11:14 PM
KevinF56's Avatar
i took the smallest alen wrench i could find and pushed the pin in.
Old Dec 5, 2007 | 11:25 PM
chuckie311's Avatar
i used a small screwdriver and pushed it though carefully
Old Dec 6, 2007 | 07:44 AM
thanks guys
Old Dec 6, 2007 | 10:44 AM
budhayes3's Avatar
PT's Slowest Truck
I used a straight pick that the tip had been snapped off of, and the rest had been smoothed out to prevent it from being sharp and piercing wires
JordanH
Dec 25, 2015 08:32 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
