6.0 or 03 LS6 405 hp
Old Jun 22, 2004 | 02:27 AM
Default 6.0 or 03 LS6 405 hp
im thinking on what engine should i get in my truck the 6.0 LQ4, LQ9 or the 03 LS6 i have a 2000 silverado rcsb, auto tranny, 2 wheel drive. if i put the LS6 would all of the accesories from the 5.3 bolt to the LS6??? i want to keep it automatic!!
Old Jun 22, 2004 | 06:45 AM
zippy's Avatar
what do you use the truck for?
Old Jun 22, 2004 | 10:57 AM
ls6 if u want speed
Old Jun 22, 2004 | 12:35 PM
Scream's Avatar
MOOBIES Moderator
I swapped a LS1 into my truck, and I love it! Stock displacement, TR224 cam, even stock truck cast manifolds, and I pulled 101mph in the 1/4. There's a LOT more left in this setup with some tuning too.
The accessories will bolt to the aluminum block (AFAIK there aren't any external differences b/t the LS1 and 6 blocks) except for one bolt on the truck a/c compressor bracket.
You can keep all of the accessories, intake & exhaust manifolds, etc from the truck motor and put them on the aluminum block. You save around 80-100 pounds off of the nose of the truck with the aluminum block, which is one of the reasons I like the swap so much. All you're really doing is swapping the iron long block for the aluminum one.
Good luck!
Old Jun 22, 2004 | 03:45 PM
tooquick2beslo's Avatar
Get the LS6 and be done with it.
I also believe that you can get a warranty with that engine as well.
Old Jun 22, 2004 | 03:58 PM
greentahoe's Avatar
What are the LS6 going for?? I would think that for the price of an LS6 you could get a 6.0 longblock ($1200) and a centrifugal blower ($3000). Now thats fast (in comparison to just an LS6).
Old Jun 22, 2004 | 07:48 PM
5.3truckin's Avatar
but it would be cool to say u have a z06 motor in ur truck
Old Jun 22, 2004 | 08:14 PM
Black02Z71's Avatar
Yeah but you could build one hell of a motor, out of a 6.0 for the price of a LS6, I think there like $5000, I bet you could build a 408 out of a 6.0 for cheaper, and whats cooler than having 408 cubic inches.
Old Jun 22, 2004 | 08:24 PM
I personally would rather have a warranty with the motor for at least one year.
No worries for one year and still have one hell of a engine that you know has 405 hp and you are not guessing at it. Just my opinion.
Old Jun 22, 2004 | 08:50 PM
Black02Z71's Avatar
LS6 405HP #88984272 $5150 Long block
LQ9 345HP #88984279 $3095 Long Block
All you need is a cam in the 6.0 and it will make more power than the LS6. The LQ4 and LQ9 use cylinder heads with the same ports as the LS6, the only difference is the chamber size. Add it up, 6.0 has the same heads, larger bore, all its missing is a cam. You could run a pretty big cam in a 6.0, and still make more low end then the LS6.
