5 spd of auto
My boss at the garage i work at has really good connection to a junk yard. there is a 5 spd sivlerado there...like a 2000. i was wonder if i could swap this into my truck. And i know how much work is involed. so would a 5 spd be quicker?........
I agree. Try to find a 5-speed truck to go drive. See if you like it before you invest in it. It's not aperformance trans, it's a truck trans - first gear is a granny. Also, the 5-speed has torque limitations. That is the reason you don't find them installed behind motors bigger than the 4.8. A T-56 swap would be a lot more fun to drive. Those also have 2 overdrive gear ratios, cruising at high speeds will be more economical.
I need the cross member and pedal assembley out of that truck!
Working on it! Click here and "Projects" = http://members.aol.com/BHowe79/02Silverado/Index.htm
Already did it = https://ls1tech.com/forums/showthread.php?t=236068
Originally Posted by bourbeaugmcx
T-56........that would fit......who has done this
I live in Vermont, so if your really thinking about doing this i could give u the #, and address to the yard.
You can PM me the info.
dantheman1540
14
Sep 28, 2015 09:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
