5 spd of auto
Old Nov 12, 2004 | 07:31 PM
bourbeaugmcx's Avatar
Default 5 spd of auto
My boss at the garage i work at has really good connection to a junk yard. there is a 5 spd sivlerado there...like a 2000. i was wonder if i could swap this into my truck. And i know how much work is involed. so would a 5 spd be quicker?........
Old Nov 12, 2004 | 07:32 PM
sorry....5 spd OR auto
Old Nov 12, 2004 | 10:19 PM
Start2Fabrication's Avatar
i'd get all of the conversion parts (pedal, master, etc..) except the tranny itself, then go buy a nice T56 and hook it all together.
Old Nov 13, 2004 | 02:32 AM
James B.'s Avatar
I agree. Try to find a 5-speed truck to go drive. See if you like it before you invest in it. It's not aperformance trans, it's a truck trans - first gear is a granny. Also, the 5-speed has torque limitations. That is the reason you don't find them installed behind motors bigger than the 4.8. A T-56 swap would be a lot more fun to drive. Those also have 2 overdrive gear ratios, cruising at high speeds will be more economical.
Old Nov 13, 2004 | 03:43 PM
T-56........that would fit......who has done this
Old Nov 13, 2004 | 08:38 PM
1TRUESS's Avatar
I need the cross member and pedal assembley out of that truck!
Working on it! Click here and "Projects" = http://members.aol.com/BHowe79/02Silverado/Index.htm
Already did it = https://ls1tech.com/forums/showthread.php?t=236068
Old Nov 14, 2004 | 03:58 AM
Yeah man deffinately go with the t56 our 5spds suck!!! They can't handle any power mods. I am lucky to have limped 49K out of mine.
Old Nov 14, 2004 | 12:50 PM
I live in Vermont, so if your really thinking about doing this i could give u the #, and address to the yard.
Old Nov 14, 2004 | 04:06 PM
BigBlockChev572's Avatar
Yes, do not get the New Venture gear 3500 (5spd in out trucks). They have a 285HP power limit.
Philip S.
Old Nov 14, 2004 | 07:16 PM
1TRUESS's Avatar
That would be great! Thinking about doing it? I have already started the swap!
You can PM me the info.
SloSVO
Nov 22, 2020 07:34 PM
dsbodley
Nov 14, 2015 09:46 PM
Rockrz
Sep 29, 2015 09:07 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
