5.3L, want more power!!!!!!!!!
Old May 13, 2013 | 10:51 PM
eds01sierra's Avatar
Default 5.3L, want more power!!!!!!!!!
alright here is the deal i just sold my other car and now i have 1100$ to put into my truck i want to get the most power out of my truck my current installments are in my signature and if i left any out that people may post i will let u know if i have it, well i want to get some easy installation upgrades, but me and my dad were going to try to find a cam and some heads, any other ideas? my dads friend owns a shop that strictly does LS based engines and he said i could get 400RWHP with just 1000$ and ideas on how to get more with the same amount of money?
Old May 13, 2013 | 11:04 PM
kelsey_canard's Avatar
400rwhp on a lm7 is pretty difficult. IMHO heads on a 5.3 aren't the best bang for the buck. Id rather put the money towards a 6.0 than heads on a 5.3. Sometimes, increasing RWHP is not always the most efficient way to better E.T.s at the track. A properly setup bolt on truck can outrun a head/cam truck without the appropriate supporting mods. Put the money in a tires/tune/stall/gears/headers. In respective order. I tried everything backwards and it was not the best idea.
Old May 13, 2013 | 11:24 PM
La Grey 1's Avatar
cam/headers.... or gears/posi
Old May 13, 2013 | 11:43 PM
dmelvin's Avatar
You're going to spend $300 on a custom tune, 300 on a cam, not including everything needed for a swap including the gaskets, new crank bolt, etc. 500 for a set of LS6 heads if you're wanting a budget build.
Unless your dad's friend is building a turbo kit out of scrap pieces of stuff lying around, there is no way that he's getting 400 RWHP out of a 5.3 in a truck for $1000. Unless he's dropping a 150 shot of nitrous on one, but that can be done for less than $1000.
Old May 13, 2013 | 11:54 PM
asap216's Avatar
Sell the superchips and throttle body spacer, use that towards the cash you already got and do a cam swap and a good custom tune
Old May 14, 2013 | 12:37 AM
WICK3DxGATA's Avatar
ive got a 5.3 with headers, full exhaust, cam, tune, and stall which all together is well over a grand and im pretty sure im still under 400hp by quite a bit.
Old May 14, 2013 | 01:05 AM
Suburbazine's Avatar
I've got an LM7 that might be close to the 400rwhp mark. Granted, I spent a **** ton on it first.
Old May 14, 2013 | 01:40 PM
Alright my dad called comp cams and we are having them grind a cam that will add 60RWHP also will increase the RPM range to 7500 for 750$ anything I could easily add for 400$? Maybe some headers??? They are going to be Shorty headers
Old May 14, 2013 | 01:45 PM
Headers can be had for that. Do long tubes, not shorties. Do you have the specs on the cam? A good sized can needs stall, gears, and compression or it will be slochy down low.
Old May 14, 2013 | 01:57 PM
asap216's Avatar
How do you know how much rwhp it's gonna add? And your gonna need to spend the extra cash on parts to do the swap and a tune
