5.3l swap fuel pump relay wiring
Old Jul 6, 2010 | 10:12 PM
Mtrhd329's Avatar
Default 5.3l swap fuel pump relay wiring
So i took my harness out to rewire it and now my fuel pump relay trigger from the pcm, red#9, is putting out 12 volts but wont trip the relay. Is this line burnt out from the PCM? It has worked fine in the past. Would it be bad to run the relay coil to 12v switched and just run a switch to ground to control the fuel pump?
Is the fuel pump relay trigger supposed to even be 12v?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
lo&sloSierra
Jul 19, 2015 10:56 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
