5.3L specs?
Old Oct 18, 2004 | 11:34 AM
2001CamaroGuy's Avatar
Default 5.3L specs?
Looking for all the specs on a 5.3Liter:
- deck height
- stroke
- rod length
- bore
- compression height
- head chamber CC
- valve size
- port CC
- head flow
- gasket thickness
I have a 5.3Liter Silverado and I'm looking at doing some "minor" hopups and want to know what all I'm dealing with here.......
Old Oct 18, 2004 | 10:55 PM
fullthrottledan's Avatar
cc chamber volume-61.15cc
intake port volume-200cc
exhaust port volume 70cc
compression-9.5:1
intake valve-1.89"
exhaust valve-1.55"
hope this helps some,
Dan
Old Oct 18, 2004 | 11:25 PM
derek_silvy's Avatar
I am waiting for one of the engines in my household to blow so I can rebuild it.
Keep us updated on those "minor hopups" ok?
Old Oct 19, 2004 | 01:50 PM
thats the trick.....if I can find out what I have to work with here, then I will know how far I cam go with these "minor hopups"
for now it looks like mild port/polish/2.0" intake valve on the extra set of 5.3L heads I have sitting around and perhaps toss in the stock cam I have from my 01 F-body.....
Old Oct 19, 2004 | 01:52 PM
01Sierra's Avatar
What is the max compresion ratio on a 5.3??
Old Oct 19, 2004 | 01:55 PM
well starting from that 9.5:1 (shitty..... ), my guess would be ~10.2:1-10.5:1 with a 0.050" mill and a thin head gasket..........
Old Oct 21, 2004 | 07:19 PM
BigBlockChev572's Avatar
compression-9.5:1
intake valve-1.89"
exhaust valve-1.55"
Dan
Where did you get this info from? 200CC intake sounds way too big and a 70CC exhaust sounds a little too small even though these cams favor the exhaust side. Compression is actually 9:45:1 But seriously, where did you get the head CC info from?
Philip S.
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jscherbs
Sep 30, 2015 07:54 AM
old motorhead
Sep 29, 2015 08:22 PM
chvy=power
Sep 8, 2015 11:06 AM
