5.3L pinging problem
Old Jun 23, 2015 | 05:43 AM
  #41
03sierraslt's Avatar
Keep in mind how a 60 works, it has to apply and release and setting shift time below .25 can cause tie up. On a stock trans I doubt it will shift fast enough to do it but still not the greatest idea. Are pressures stock? Throw a shift kit in.
Old Jun 23, 2015 | 09:13 PM
  #42
GM_Devil's Avatar
Originally Posted by stock48
Yea the knock sensors don't work very well on these things I have noticed. What is command vs actual timing where you hear the ping?
heres a my log an tune. its actual is 25* and command is 28*
fast forward to about 3/4 of the log and youll see a brief wot pull, thats where i hear it.
File Type: hpt
File Type: hpl
Old Jun 23, 2015 | 09:49 PM
  #43
George C....'s Avatar
Formerly ScreamingL
Don't run shift times at 00 in a 4l60e, in a 80e its fine but not a 60e.
in the 60s ive tuned that are built i run them at zero....
for some wondering everyone knew of skeets that handled over 600 rwhp for many yrs
have others with it at zero making power and lasting but other tables are adjusted to go along with that zero'd out table
Old Jun 23, 2015 | 09:51 PM
  #44
Formerly ScreamingL
have you checked to make sure you have proper fuel delivery?
Old Jun 25, 2015 | 04:21 PM
  #45
black00chev's Avatar
Slowest turbo build ever!
I have been wondering the same thing. My previous comment/question may have gotten looked over.
I didn't see if he happened to check his fuel pressure in that RPM range. I was having a pinging issue awhile back after doing exhaust CAI and 93 tune. Turns out the stock pump wasnt able to keep up from 4500rpm and up and pressure would drop off. Dropped in a racetronix walbro 255 kit and no issues since.
So im wondering if the stock pump is just starting to go?
Old Jun 25, 2015 | 08:28 PM
  #46
GM_Devil's Avatar
That very well could be my problem...I am in Arizona and it is 115 out...
youve given me alot to think about lol
Old Jun 26, 2015 | 11:13 AM
  #47
Im not sure what you have going on compared to Jarrett, but mine would ping from about 4,000rpm and up. I can't remember if it was pulling timing or showing KR though. That was before I had EFI Live and did my own data logging.
lucas287
31
Jan 12, 2021 06:18 AM
zblee
Nov 11, 2015 12:41 AM
Tydriver
45
Oct 23, 2015 09:19 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
