5.3L pinging problem
Old Jun 6, 2015 | 07:47 PM
  #21
GM_Devil's Avatar
heres my stock 2005 5.3 tune if you still need to look at one.
File Type: hpt
Old Jun 6, 2015 | 08:41 PM
  #22
George C....'s Avatar
Formerly ScreamingL
reason ask is a joke is youre not rookie and been doing it long enough....figured have your own answers
Old Jun 7, 2015 | 05:01 AM
  #23
stock48's Avatar
9 Second Truck Club
Honestly Im not a big tuner of the stock ecu's other than WOT. Only thing I have really tuned on has been my truck and a ZL1 I built. All the KR and timing modifier tables are zeroed out on my truck.
  #24
stock48's Avatar
9 Second Truck Club
Thanks! I will log on with my laptop and take a look at it!
Old Jun 7, 2015 | 05:05 AM
  #25
stock48's Avatar
9 Second Truck Club
Tonight I pulled off intake and found Knock sensors all corroded and full of moister. Cleaned everything out and swapped in another set of sensors and harness and it runs a TON better! Zero ping now, I will have to log it and see how much timing it's pulling and adjust tune from there. Ports and valves looked surprisingly clean.
Old Jun 7, 2015 | 07:55 PM
  #26
black00chev's Avatar
Slowest turbo build ever!
Glad the knock sensors fixed it up. Might wanna check your fuel pressure too though. Mine started pinging after about 4-4500rpm a few years back. Turns out fuel pressure was dropping off cause the stock pump was getting weak.
Old Jun 8, 2015 | 02:07 AM
  #27
1FastBrick's Avatar
Custm2500's Rude Friend
Isn't the 06 os different from the 05 os like on the trucks were it goes into rep mode because the Throttle body, Tac module, and Pedal are different?
Offers still up if you want the factory tune for your Tahoe.
Old Jun 8, 2015 | 02:18 AM
  #28
Suburbazine's Avatar
On a truck that old I would have recommended pulling the valley cover and replacing valley cover gasket and knock sensor well seals. The well seals age, warp and then trap block moisture in the knock sensor well. A new harness with new plugs only stops water ingress from above, but won't solve the problem from below.
Old Jun 8, 2015 | 07:28 PM
  #29
GREENSIERRA's Avatar
kind of funny you asked this, my wifes 05 Tahoe just starting pinging a lot at WOT. I don't drive it a lot and she doesn't know any better.
I think I will start with knock sensors aswell and go from there
Old Jun 9, 2015 | 12:38 AM
  #30
stock48's Avatar
9 Second Truck Club
Thanks I will get you the vin.
Yea very well could be. I plan on swapping engine soon but I will be sure to put new seals in the lq4 before I throw it in there.
