5.3L head/cam swap and computer tuning?
Old Feb 11, 2014 | 10:37 PM
Chiphead's Avatar
Default 5.3L head/cam swap and computer tuning?
So I'm new to these LS motors. I've got a '04 LM7 in a silverado that needs heads. If I bump compression from 9.5 to 10:1, will I have to re-tune the computer? If I add a small cam like the Crane Powermax LS cam, with 200/208 on a 115LSA, will that require a tune? I need the truck to be a DD, able to tow and get good MPG with stock converter and 3.42s.
Is it possible to do ANY head/cam changes to a LS motor without it running like crap with the stock tune? The closest tuner to me is in Greenville or Charleston SC, both several hours away. From reading here, I see that some guys do their own tuning, some buy "canned tunes", some physically bring their truck somewhere and other send datalogs of their truck to a tuner and get a tune back. What would be best for my situation? Thnx!
Old Feb 12, 2014 | 01:52 AM
gamble686's Avatar
Holy baby cam batman. Not worth your time. I would suggest a mail order tune from one of the sponsors. It should be done on stock motors let alone a modified truck. You seem like a perfect candidate for a 212/218 low lift 112LSA. You will need new pushrods if you are milling the heads anyways. That should net you 50-70rwhp+ and only cost you maybe 1mpg while maintaining driveability.
Old Feb 12, 2014 | 12:59 PM
Chiphead's Avatar
I know, baby cam that won't sacrifice low-end or idle quality. I'd rather err on the small side because I don't need it to stall or creep in gear. The stock cam is 190 degrees duration, I figured 10* more would not move the powerband much and I could take advantage of more compression. How much cam can be used in 5.3L with 9.5-10:1 with PB/stock converter/3.42s?
I just did some reading on the blackbear site about tuning. Thanks!
Old Feb 12, 2014 | 01:20 PM
Chevy_King1500's Avatar
a stock engine gains from a custom tune, so yes i would get one
Old Feb 12, 2014 | 01:32 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You can run up to a 212/218 low lift with out hurting low end. But I would dump those 3.42 especially for towing.
Personally for an everyday DD I would run 3.73's
At times I wish I had 4.10's until I get past 70 MPH
I have 3 trucks and I absolutely hate the 3.42's especially for towing.
Old Feb 12, 2014 | 06:25 PM
Hex Hacker's Avatar
Registered User
What is your location?
You can find a few other tuners in the state
Old Feb 12, 2014 | 09:55 PM
Chiphead's Avatar
I'm in western SC, about 30 minutes east of Augusta Ga. I bought the truck new, and it's box stock except for a mild shift kit and Z-pack clutches in the tranny.
Old Feb 12, 2014 | 10:06 PM
GMCtrk's Avatar
You seem like a smart dude. That 200/208 will be perfect for what you're wanting. Avoid the temptation to go any bigger.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chevyl33
Aug 24, 2015 08:21 AM
CammedZ71
Aug 2, 2015 01:44 AM
lxcoupe
Jul 14, 2015 10:14 PM
Nimoryan
Jul 5, 2015 03:50 PM
