5.3 vs 5.7
Old Feb 11, 2004 | 02:28 PM
Sport Side's Avatar
Default 5.3 vs 5.7
Hey, i was just wondering a couple things about the 5.3 and 5.7 engines. how come it seems, f-body guys stick a cam in and w/ free flowing exhaust and intake, there pushin 350+rwhp, but w/ the same mods on a 5.3L we'd probably be hittin near the 300rwhp mark? just lookin for an explanation.
thanks,
Old Feb 11, 2004 | 02:43 PM
Buckwheat's Avatar
thanks,
Heads and tuning mostly. I wouldn't compare rwhp numbers between the two personally. Get a baseline dyno for your truck and go from there. I think you would find that your hp/tq increases would be about on par with the increases a Fbody given the same mods. If you were to drop in a LS1 you would not dyno as high as a car because you have alot more powertrain loss in the truck.
Old Feb 11, 2004 | 02:44 PM
Buckwheat's Avatar
thanks,
Heads and tuning mostly. I wouldn't compare rwhp numbers between the two personally. Get a baseline dyno for your truck and go from there. I think you would find that your hp/tq increases would be about on par with the increases in a Fbody given the same mods. If you were to drop in a LS1 you would not dyno as high as a car because you have alot more powertrain loss in the truck.
FILE's Avatar
The 5.7 ls1 is very underrated. I think it's rated @ 305 hp and many put 29X at the rear wheels stock.
Old Feb 11, 2004 | 02:51 PM
F8L Z71's Avatar
Yeah, rated at 305HP but most Autos do 290-310rwhp and sticks can go as high as 315rwhp bone stock. That is essentially a 350HP motor.
Old Feb 11, 2004 | 03:38 PM
So what exactly is the difference between the 310 HP LS1 in the camaro and the 350 HP LS1 in the corvette?
Old Feb 11, 2004 | 03:43 PM
marc_w's Avatar
I don't think much... I used to hear F-body guys saying that GM underrated the F-bodies so that people would have an excuse to lean towards the 'more powerfull' Corvette.
Old Feb 11, 2004 | 04:13 PM
I think the driveline loss between the F-bodies isn't that much different. I imageine it is about the same % loss as a Vette. The rearend takes more power, and the longer driveshaft. I think it is a combo of the smaller displacement, heads, compression, and smaller cams.
Old Feb 11, 2004 | 04:49 PM
MilDot's Avatar
The intake path from the filter to the throttle body was obstructed on the F-body. This seemed to be GM's way of restricting power on the F-body, and why 10-15rwhp gains were seen from a airlid swap on a stock car. As far as the motor, no difference.
Sport Side's Avatar
i was wonderin how those camaro guys were makin 130+hp w/ a cam and some bolt ons.
w/ the camaro bein under rated it does make a lil bit more since now and seems a bit more reasonable
thanks
TAPyvehc93
Dec 27, 2015 12:14 PM
pewter00
Sep 14, 2015 09:17 PM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
