5.3 tune on 6.0.
#43
You said the motor sat for quite a while right? After I did my cam swap, my engine had a mad ticking noise. Got the video to prove it. I thought for sure I F'd something up. Ran for a couple minutes and it didn't go away. I turned it off, torqued all the rocker arms again one last time (nothing changed). Put back together and it fired to life with no more loud tick. I could only fathom it being a lifter or two that failed to pump up in the short time I ran it the first time. Have your junk yard check the lifters and make sure they are not collapsed.
#44
I would think a decent mechanic would be able to tell if it were in the top end or in the rotating assembly. I'd be seriously suspecting the lifters as well. I'd definately want them replaced while the head is off. LS7 lifters aren't much.
#45
Ya it did sit was covered tho. An i would assume they checked the lifters an all when they pulled the heads. Im not very motor savvy but i kno a little bit. An i just want it running its been down almost 4 months an its my dd, i will worry bout upgrades after the new yr.
