5.3 tune on 6.0.
Old Oct 12, 2010 | 08:32 AM
  #21
blsnelling's Avatar
Originally Posted by youngbuck
How expensive/ difficult if the bearing is bad?
Requires a complete tear down and rebuild. If you've got a bad bearing, you've got a damaged crank.
Old Oct 12, 2010 | 09:27 AM
  #22
youngbuck's Avatar
An has 48 pounds of oil pressure.
Old Oct 12, 2010 | 05:15 PM
  #23
youngbuck's Avatar
Talked to the junkyard, gota trailer the truck to them and there goin to work on the motor no charge.
Old Oct 12, 2010 | 07:52 PM
  #24
mhotrodscooter's Avatar
Still not smart, but better then anything else... Good luck. That motor is junk lol
Old Oct 12, 2010 | 08:20 PM
  #25
youngbuck's Avatar
O well thanks man. God forbid a lil bit of positivity lol.
Old Oct 12, 2010 | 08:43 PM
  #26
I'm just saying I hope their smart enough to know it's junk & they put you another one
Old Oct 12, 2010 | 10:11 PM
  #27
youngbuck's Avatar
Yea well this is wat they wanna do 1st, so ima play ball there way.
Old Oct 13, 2010 | 03:49 PM
  #28
youngbuck's Avatar
Just heard my truck, its not knocking but is a loud ticking tht gets louder with rpms. Sounds like its halfway up, not in the bottom so much. Thoughts?
Old Oct 13, 2010 | 04:09 PM
  #29
blsnelling's Avatar
Bad lifter, worn cam, bent pushrod, bad rocker arm, broken valve spring, loose rocker arm bolt..................
Old Oct 13, 2010 | 04:16 PM
  #30
youngbuck's Avatar
Its a fast ticking also.
