5.3 safe?
I've been trying to figure out what parts have a possibility of failing after I'm done installing everything, here is what I'll be running:
1. Yank TC - 3000 stall
2. Street tune
5. PaceSetter LT headers w/ Y-pipe
6. TR224 cam w/ Comp 918's
7. 4.10 gears
8. FLT Level 4 trans
10. Eaton posi
11. Full bolt-ons
And by the end of this month I plan on adding a 75-100 shot as well, but I won't be spraying very often. Is this too much for the 5.3 when on the bottle? Are there any stock parts that I need to upgrade such as injectors etc..? I'd hate to blow this thing, though a built 6.0 does sound nice! Any help at all is appreciated!
2. Street tune
7. 4.10 gears
10. Eaton posi
11. Full bolt-ons
sounds like you have a good combination of parts there. i know my injectors are maxed out (103% d/c) however i'm still not running lean. i would upgrade the injectors to be safe side cause you'll probably need them with the spray.
i put an inline pump in and with a 100 shot my injector duty cycle was at 91% on stock injectors, but other wise you have to close to the same set up i got and i have no probs..i just wanna go faster
