5.3 Questions
Old Jul 14, 2007 | 05:39 AM
SquareOne's Avatar
Default 5.3 Questions
I was browsing the chevy website when I came across this:
Cylinder-Head Technology *— the small block V8 cylinder heads were originally developed for the Corvette Z06. Their pent-roof combustion chambers and flat-top pistons deliver high horsepower.
I've looked for more information regarding them and am curious as to their potential. Anybody have any experience with them?
Just things I consider when I'm at work dreaming of horsepower...
Old Jul 14, 2007 | 08:35 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Looks like the L33 with the 799 head castings
Edit:Looks like the new Gen IV with DOD
Vortec 5.3L aluminum-block V8 engine features:
From the family of redesigned Gen IV Vortec V8 engines
315 horsepower @ 5200 rpm
338 lb.-ft. of torque @ 4400 rpm
EPA estimated 16 city/20 highway MPG in 4x4 models
Standard Hydra-Matic four-speed automatic transmission
Lightweight — yet strong — deep-skirt aluminum block
A cast-iron crankshaft with undercut and rolled fillets
Cast-aluminum cylinder heads that feature a low-friction roller-rocker valvetrain
Electronic Throttle Control provides outstanding throttle response, greater reliability and improved efficiency
A faster, smarter Engine Control Module with more memory that better synchronizes the multitude of engine operations that occur every split second
A thermoplastic composite intake manifold that helps keep the air intake cool. And equal-length runners feature smooth interior passages to promote high-speed airflow to each cylinder
Hydraulic engine mounts for improved vibration isolation
A coil-near-plug ignition system for a precise delivery of high-energy spark
A coolant loss protection feature allows the Silverado to be driven a limited distance at a reduced speed in order to reach a service facility even if a catastrophic reduction in the coolant level has occurred
Extended-life spark plugs and engine coolant
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
