The 5.3 from hell!!!!
Old May 3, 2014 | 11:01 PM
Hubcap's Avatar
Default The 5.3 from hell!!!!
I have been building a 5.3. This damn thing keeps eating bolts!! First one was a main cap was never close to spec was on torqued at 25 ftlbs when it broke. I was fine with that one. Got the short block done was putting the heads on with arp head bolts was torquing the bolts by the lifter valley one of those broke. Then I was pissed.took a couple days off from it. The last thing was doing was putting the rockers on started them with my hands and first I did and I'll be damned a damn rocker bolt broke I took what was left of it out with my fingers. What the hell is wrong with this damn thing. Checked the rest of the hole and the bolts will only get one or two threads with my fingers before they are tight what do I need to to get this right?
Old May 4, 2014 | 12:58 AM
WayneG's Avatar
I think chasing the threads with a tap would probably be a good place to start if you haven't already tried it. Good luck
Old May 4, 2014 | 03:52 PM
Hubcap's Avatar
Just chased the threads. And some will fit some won't does anyone have any ideas on what else I can do.
Old May 4, 2014 | 03:54 PM
BlackGMC's Avatar
Resident Retard
Sounds like you need a new block or torque wrench.
Old May 4, 2014 | 03:55 PM
Hubcap's Avatar
Are the rocker bolts torque to yield bolts ? Are they all the same size from 862/706 head
Old May 4, 2014 | 03:59 PM
Hubcap's Avatar
Yeah man I'm close from pulling my stuff off this thing and putting it in my running 4.8 I have been really debating it. I'm sick of this motor it has gave me nothing but problems from the time I got it.
Old May 4, 2014 | 11:56 PM
Jeebalow's Avatar
What torque wrench are you using? If it's a clicker type and you're using it close to it's min torque setting, the click is barely noticeable. I actually broke a head stud that way because I never felt the click. I bought an in-lb torque wrench so I could use it higher in it's range. Plus it's shorter so you have a shorter lever arm and are less likely to overtighten.
Old May 7, 2014 | 07:14 AM
gagliano7's Avatar
The rocker bolts are only 22 ft lbs for torque and they aren't tty. You must be over torqueing everything. Pretty hard to break an arp head bolt unless you are over torqueing. Your lucky the rocker arm bolt broke before the aluminum head cracked.
Old May 8, 2014 | 12:40 PM
04Hall's Avatar
I vote on gettin a new mechanic.
Old May 8, 2014 | 05:57 PM
Hubcap's Avatar
I know when I took this motor apart everything was so damn tight I broke a snap-on 1/2 inch ratchet. I used they old arp head bolts. It's not the head bolt I'm worried about the rocker bolts want thread in the heads I cleans them out and it seems like the bolts are just I little to big. I don't know why they came out of the motor
pewter00
Sep 14, 2015 09:17 PM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
pewter00
Sep 7, 2015 10:14 PM
