5.3 Fuel Fix?
Old May 26, 2002 | 05:50 PM
z71tahoe's Avatar
Default 5.3 Fuel Fix?
I was told that my 2002 5.3 (flex fuel motor) has a problem with the fuel supply when supercharged (ATI Kit). Apparently the regulator only allows for 40pounds of fuel at idle, and I should have 60. (My fuel guage has confimed the 40)
I was told that I needed to purchase a fuel rail assembly and regulator from a non flex-fuel vehicle (Whipple).
Does anyone think this will work? I priced everything out (<$500) but I do not want to to have buy new rails if I just need the regulator.
I have a few pics of my truck on the web Z71 Supercharged
Old May 26, 2002 | 06:45 PM
GMC SKI's Avatar
Default Re: 5.3 Fuel Fix?
hey Did that tube that you have come with the ATI kit ?where did you get it from?
I'm still using the stock tube ..that keeps blowing off
I too am having fuel supply problems
what's the inline pump rated at that comes with the kit ?
Have you dynoed the truck yet ?
what's your air fuel ratio at ?
Old May 26, 2002 | 08:43 PM
oxidizr's Avatar
Moderator / Sponsor
I have one brand new 6.0 fuel rail-crossover tube set / regulator (adjustable OEM) / and 5.3L injectors and one used 5.3L fuel rail-crossover tube set / another 5.3L regulator (adjustable OEM) I may be willing to part with depending on how my custom rails test with the 8.1L injectors. Take a picture of your rails and post or e-mail...I curious to see how they differ.
Richard
BTW- does your truck have an adjustable and/or vacuum boost style regulator?
RW
<small>[ May 26, 2002, 08:45 PM: Message edited by: oxidizr ]</small>
Old May 26, 2002 | 09:52 PM
parish8's Avatar
single digit dreamer
oxidizer.. why the new fuel rails? wont the 8.1 injectors work with the stock rails?
Old May 26, 2002 | 10:18 PM
z71tahoe's Avatar
My problem is finaly figured out. I am definitely not getting enough fuel. If i floor the truck from a stop the FMU keeps up with the demand and the truck never runs lean- BUT when driving normal and suddenly stepping on it the FMU will not keep up when the tranny drops down a gear it runs lean for a second but by then its to late- How can I get my FMU to kick in early? Is there a way to make my stock regulator allow more fuel than 40? I am sure i should have 60 at idle.
GMC SKI - I think you are referring to my K&N intake tube. Even that had to be reinforced to hold up to the boost- but I have no problems with tubing. The inline pump that came from ATI gives me at least 100psi to the rails when my truck hits 8psi boost. I have not dynoed the truck yet but it goes in for the exhaust next week and on the dyno june 4th-
oxidizr - I would be interested in purchasing your rails/regulator if that is what I need to do. I really want to have more fuel pressure at idle- I will take a picture of my rails tommorrow and post on my page.
Old May 26, 2002 | 10:51 PM
oxidizr's Avatar
Moderator / Sponsor
parish8:
Yes... but the factory crossover is small, the regulator is very restrictive and the factory rails have a restrictor/divider which slows fuel delivery (was offered by factory for more even pressure along the entire rail.) With the new pump and extruded rails I don't perceive even delivery will be as important as volume. Yes the 8.1's are interchangeable.
Ben Tickner
Once you post and I can identify the differences I will part with some of my spare goodies. Check to see if your regulator on the return line of the rail has a #10 security torx bit...if it does you can adjust the idle pressure...if it is the same as the non-FF regulator, I have an extra OE adjustable regulator you can swap in its place...just let me know.
Richard
Old May 27, 2002 | 09:44 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Sorry, I can't help with your blower problems, But I just wanted to say that is one BAD *** Tahoe! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 27, 2002 | 08:05 PM
GMC SKI's Avatar
What is everybody's fuel preasure at idle ?
how much can i get out of the adjustable regulator.
if i crank it up it will give me more presure and fuel at all rpms?
Old Oct 23, 2011 | 09:11 PM
stephenspann27's Avatar
Back from the dead!
I have a 2002 Z-71 Tahoe that is Flex Fuel. I am having problems with pinging under hard acceleration. I checked the FP and when I saw that I only had 42PSI I thought the pump must need to be replaced. I replaced the pump and the pressure is the same. Now I know that the specs are different for flex fuel tahoes.. bummer. Even when I unplug my FPR the pressure doesn't go over 52 PSI so I"m guess just swapping the FPR won't raise the pressure much.
5.3Okasai
Mar 9, 2022 01:07 PM
chevyl33
Aug 24, 2015 08:21 AM
hartinclay
Aug 3, 2015 07:03 PM
MS3Z
Jul 30, 2015 06:17 PM
