5.3 engine mods?
Old May 31, 2011 | 09:26 PM
andrew383's Avatar
traveling mod
Yeah the cam itself will run about $400..But you'll need new springs,gaskets at the very minimum..
Most change the timing chain,lifters,knock sensors and push rods also..
A cam or headers are both worth the time WITH a tune to follow,other wise its just wasted $$..
An aftermarket converter(stall) lets the engine rev higher to get in the power band quicker..
The stock converter flashes at about 1800-2000rpm..Then say you get a 3200 stall converter it will flash to about 3000-3200rpm..
A good investment to get a heavy truck off the line
I and many others run the Circle-D 3000-3200 converter which runs $400..
Old May 31, 2011 | 09:28 PM
02sierraz71's Avatar
Registered User
Originally Posted by rjwz28
Cams aren't expensive, but that price was the estimate for a cam swap. There is usually more parts swapping when you change camshafts, hence the extra $300-500 cushion.
oh i see. if i buy a decent performance cam would i be able to run it without too much stress on my engine. i'm not trying to build a drag truck or anything but i do want it to beat all of my friends, which shouldnt be hard since most of them have pretty crappy trucks ha.
and how much of a power increase can i expect with a $200-$300 cam?
Old May 31, 2011 | 09:38 PM
Registered User
oh that seems like a pretty good investment since my 5.3 does seem pretty sluggish in the lower rpms. seems like it would help with towing too, which i do occasionally. did it hurt your gas mileage any?
and to everybody that replied to this thread, thanks so much for the great info and your patience since im obviously not the most informed person on this forum
Old Jun 1, 2011 | 06:14 AM
rjwz28's Avatar
Man Motor club
For towing you need to use a multidisk converter, which is a bit more pricey. Circle D's runs about $1050-1100. That's the only reason I don't have one
Old Jun 1, 2011 | 07:20 AM
Coban's Avatar
Nothing is going to make as much difference as the 6.0 swap if you want actual, usable power.
Old Jun 1, 2011 | 07:50 AM
dmelvin's Avatar
Circle D rates their 278mm single-disk converter to tow 4000lbs with the aftermarket cooler. Which they also sell.
Old Jun 1, 2011 | 08:16 AM
rjwz28's Avatar
Man Motor club
Oh really? Hmmm. My truck is rated to tow 10k, but will I need to do that anytime soon? That makes things a little harder to decide. How much does that run?
Old Jun 1, 2011 | 08:19 AM
rjwz28's Avatar
Man Motor club
Okay for your purposes and trans this converter is perfect. Pick the stall speed you want and go
http://circledspecialties.com/p-50-g...converter.aspx
Old Jun 1, 2011 | 08:21 AM
rjwz28's Avatar
Man Motor club
And here is your cooler
http://circledspecialties.com/p-80-tru-cool-40k.aspx
Now I just need to see if they offer something similar for my combo (6.2 6L80E) or if I just need to save up for the triple-disc.
Choda
Jan 22, 2026 02:03 PM
steves86ta
Jul 28, 2015 10:21 AM
bk_cauley
Jul 19, 2015 09:56 PM
black6spdz
Jul 16, 2015 01:32 AM
ALynch
Jul 6, 2015 09:49 AM
