5.3 engine mods?
Yeah the cam itself will run about $400..But you'll need new springs,gaskets at the very minimum..
Most change the timing chain,lifters,knock sensors and push rods also..
A cam or headers are both worth the time WITH a tune to follow,other wise its just wasted $$..
An aftermarket converter(stall) lets the engine rev higher to get in the power band quicker..
The stock converter flashes at about 1800-2000rpm..Then say you get a 3200 stall converter it will flash to about 3000-3200rpm..
A good investment to get a heavy truck off the line
I and many others run the Circle-D 3000-3200 converter which runs $400..
and how much of a power increase can i expect with a $200-$300 cam?
and to everybody that replied to this thread, thanks so much for the great info and your patience since im obviously not the most informed person on this forum
Okay for your purposes and trans this converter is perfect. Pick the stall speed you want and go
http://circledspecialties.com/p-50-g...converter.aspx
And here is your cooler
http://circledspecialties.com/p-80-tru-cool-40k.aspx
Now I just need to see if they offer something similar for my combo (6.2 6L80E) or if I just need to save up for the triple-disc.
Choda
Jan 22, 2026 02:03 PM
