5.3 to 5.7 few ?'s
Old Dec 11, 2006 | 09:02 AM
phatboy's Avatar
Default 5.3 to 5.7 few ?'s
if i do a 5.7 in my truck should i keep the stock 5.7 heads and intake or use the 5.3's ive heard a few different suggestions but no definate answers. which combo makes more horsepower, compression etc. truck is in my sig, 5.7 is out of a 2000 f-body. if i drop the complete motor in i assume my computer will work for this?
Old Dec 11, 2006 | 02:26 PM
onebadrubi's Avatar
You should already have a truck intake. Which provides more torque in low rpms. If you bore your truck to a 5.7l you may or may not want to use the ls6 or similiar manifold. The ls6 manifold will help you maintain power up high, 6000+rpms where as the truck intake will begin to not flow as well up above these rpms.
The heads on your truck FLOW the same as ls1 heads just increase compression. So I would leave your stock 5.3l heads on your 5.7. many ls1 cars do this just to increase comp for cheap.
Old Dec 11, 2006 | 07:16 PM
Dirty 30's Avatar
LS1Tech Whore
the valves on the 5.3L are smaller and the smaller combustion chamber will bump compression to around 11:1
Im in the process of installing a 5.7L LS1 with an LS6 cam and stock 5.3L heads in my V6 truck. I plan on getting the heads ported with bigger valves later on so im not too worried about that HP loss or HP that could of been there.
Old Feb 28, 2007 | 08:25 PM
06sierra5.3's Avatar
Default no room for bigger valves
theres not really any room to increase valve size on a 5.3 head. i have a 5.3 i plan on porting the stock heads and using the sodium filled corvette exhuast valves (theyre the same size) and replacing the stock intake valves with titanium valves of the same size.
Old Feb 28, 2007 | 09:08 PM
twobit's Avatar
I put z06 sodium filled exhaust valves in mine and also the bigger intake valve. Working good so far.
TAPyvehc93
Dec 27, 2015 12:14 PM
pewter00
Sep 14, 2015 09:17 PM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
