5.3 with 375 HP
Old Aug 3, 2004 | 07:46 AM
OldNovaGuy's Avatar
Default 5.3 with 375 HP
Does anyone have any suggestions on what CAM, head mod, injectors and whatever else I need to reach a minimum 375HP on a 5.3? This will be installed in a 66 Nova.
Old Aug 3, 2004 | 07:52 AM
Sport Side's Avatar
Hey,
Are you talking about at the flywheel, or referring to rwhp?
Also, Will you use a power adder? (nitrous, blower, turbo)
Old Aug 3, 2004 | 09:12 AM
L-EATER's Avatar
11 Second Truck Club
Not "will you use a power adder" but "you will use a power adder" 375 hp is attainable with 325 cubic inches, but it is way easier with a blower. Before I took mine out it made 338 with the headers, ram air, tuning, and about 8psi. I would suggest a killer set of heads and a custom cam ground to match and then a procharger.
Old Aug 3, 2004 | 10:13 AM
F8L Z71's Avatar
Well put it this way. I made 304rwhp in my truck with just basic bolt-ons and a beefy 225/.535/112 cam and stock heads. With tuning I believe I was around 315-320rwhp judging by my increased trap speed after the tuning. That rigth there is pretty damned close to your # if you add 20% for drivetrain loss and the fact my wheels are much heavier than anything you'll run on your Nova.
Now, just add a good set of ported heads with some extra compression and an underdrive pulley and I have no doubt you could get about 330-350rwhp out of the 5.3L which would put you somewhere close to 390-420HP NET.
Old Aug 3, 2004 | 10:32 AM
Do what i did. I think I'm in that range.
LPE 218/229 .560 113LSA Cam
Heads milled .050 and ported 10.3:1 compression
32Lb. injectors
Bolt ons
Cutouts
And a few more simple things here and there.
Old Aug 3, 2004 | 10:56 AM
BigKID's Avatar
I recently put down 300rwhp/305rwtq with all the boltons(cia, headers, exhaust, pullies, tunning) and a stock 2k vette cam. I am installing a FMS 214/216 .535/.545 113+4 cam, Home ported heads milled .040 and 42# injectors this weekend. I am hoping for around 350-360 to the wheels when I am done.
Old Aug 3, 2004 | 11:38 AM
OldNovaGuy's Avatar
32Lb. injectors
Bolt ons
Cutouts
This is more like what I was thinking might get me in the ballpark.
Any problems milling the head that much? What valves are you using?
I will also be running the 4L60E. What converter do you recommend?
Old Aug 3, 2004 | 11:49 AM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Most of the F-Bodies seem to work best with like a 4000 - 4200 stall, but I'd probrobally go with something like a 3500 Yank or Vigilante.
Old Aug 3, 2004 | 11:54 AM
Sport Side's Avatar
Give Allan a call at Futral MotorSports. I bet they could throw together a great package for you
--they are a sponsor on the right side of screen
pewter00
Sep 14, 2015 09:17 PM
11MPG
Sep 10, 2015 08:34 PM
jleews6
Sep 8, 2015 10:17 AM
11MPG
Sep 8, 2015 04:52 AM
pewter00
Sep 7, 2015 10:14 PM
