4wd/awd guys, look what someone gave me
Old Jan 4, 2004 | 05:59 PM
parish8's Avatar
single digit dreamer
Talking 4wd/awd guys, look what someone gave me
this is a front diferential from a 2500HD that had a duramax in it. it spun the outer pinion bearing and messed up the race land area. they were going to throw it away i hope to at least get some measurements with it to see if one would fit in a 1500, it is seriously beefy and i have my doubts. if it would fit i think i could fix it, maybe knurl the race area or get a larger race and have it machined larger.
right off the bat i can tell you the flanges are larger, i will have some measurements of a few things soon, waiting for my truck to dry off a little, it is snowing here.
Old Jan 4, 2004 | 06:31 PM
L-EATER's Avatar
11 Second Truck Club
If ya end up using it I would accept your old one if you decide to give it away! I am still toying with the idea of converting my truck to AWD.
Old Jan 4, 2004 | 06:53 PM
parish8's Avatar
it doesn't look promising, the flanges are much larger, the over all width is at least 1" wider. i can't tell by looking at it if it would bolt in but it looks prety tight, there isn't much room between the 1500 unit and the oil pan, if it does fit it will be hanging down 2" lower than the 1500 one. hmmmm
Old Jan 4, 2004 | 07:05 PM
Banned
damn, i wish someone would give me stuff like that. nice find parish. hey, you should do a full writeup on the 4l80 conversion on your website for us little guys. thanks man for being a pioneer
Old Jan 4, 2004 | 07:30 PM
Micheal Tomac's Avatar
9.25 IFS made by AAM
Old Jan 4, 2004 | 09:14 PM
Black Blown 02's Avatar
So whats our front diff? 8.5"?
Old Jan 4, 2004 | 09:31 PM
BigTex's Avatar
Great find. Thats good info.
Old Jan 4, 2004 | 10:40 PM
parish8's Avatar
what front ends are avaliable for these trucks? are there only 2 or is there one in the middle of this one and the stock 1500 unit?
anyone familur with lockers for these fronts?
Old Jan 4, 2004 | 10:41 PM
10 Second Club
Looks very familiar.
I just had mine out of my truck all torn to pieces to install my eaton front e locker. The smaller IFS housing uses an 8.25 inch ring gear. I've always thought that the 2500HD 4x4 trucks would be nice with a solid front axle. They can be converted, but it is very expensive.
Old Jan 5, 2004 | 01:35 AM
There are no lockers available for the 8.25" diff that is in the 1500s, but there are a good amount of options out there for the 9.5" from the 2500s. I dont think you will be able to get it to fit without a lot of work. If you do get it to work id put a detroit locker in there or just weld up the spider gears if you only plan on using the 4x4 when going in a straight line.
no there was never any other IFS front diff used either
