4L80e/TransGo Shift Kit/Line Pressure
Old Mar 31, 2005 | 11:05 AM
moregrip's Avatar
what a rush!
Default 4L80e/TransGo Shift Kit/Line Pressure
what change to line pressure did you perform when you put the shift kit in your tranny?
Old Mar 31, 2005 | 02:50 PM
moregrip's Avatar
what a rush!
I know there are folks around here that can answer this,
p-l-e-a-s-e
Old Mar 31, 2005 | 03:36 PM
Eye-P's Avatar
the kit is designed to use the stock trans settings.
Old Mar 31, 2005 | 04:34 PM
moregrip's Avatar
what a rush!
thanks, I was also wondering what guys like parish might have done as well.
Old Mar 31, 2005 | 04:46 PM
FLP did mine ,so I don't know.
Old Mar 31, 2005 | 04:47 PM
moregrip's Avatar
what a rush!
hehehe, damn
Old Mar 31, 2005 | 05:52 PM
FILE's Avatar
TTT... I'd like to know this too.
Old Mar 31, 2005 | 07:20 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I'm not 100% positive but you don't have to change the line pressure settings if you get a shift kit. That's the point of the shift kit...to firm up the shifts mechanically instead of electronically, which is what you're doing when you raise the line pressure. Please correct me if I'm wrong.
Old Mar 31, 2005 | 07:22 PM
moregrip's Avatar
what a rush!
not sure, I hope thats the case, because then it will be a no brainer, but I am no longer stock on these values.
Old Mar 31, 2005 | 07:37 PM
Also, if you get a shift kit TM will be ALOT more noticeable, annoying even.
