4l80e temp stuck at 284
Old Sep 6, 2018 | 12:20 PM
Crysis450's Avatar
Default 4l80e temp stuck at 284
I have a 4l80e and according to the scanner temp is at -38 and after driving a bit goes to 284 and nothing else can this be the temp sensor? Transmission is stock other than a stall, i disabled the trans over temp to get it out of safe mode
Old Sep 6, 2018 | 12:31 PM
03sierraslt's Avatar
Sensor is in the harness on the valve body.
Old Sep 6, 2018 | 06:07 PM
Crysis450's Avatar
So is it most likely the sensor then
Old Sep 7, 2018 | 05:45 AM
madmann26's Avatar
With that kinda temp, I would hope so. The sensor is submerged in trans fluid.
Old Sep 9, 2018 | 03:11 PM
Crysis450's Avatar
where is the sensor I've been looking online for it and I can't find it
Old Sep 9, 2018 | 03:24 PM
madmann26's Avatar
Pretty sure if have to get the entire harness.
How old is the trans? It may be worth refreshing the solenoids as well.
Old Sep 9, 2018 | 04:24 PM
Crysis450's Avatar
Yeah i found it, its not a intergraded with the harnes you can unclip it i replaced it and didn't fix the problem?
Old Sep 9, 2018 | 04:26 PM
Crysis450's Avatar
Its called a thermistor
Old Sep 10, 2018 | 10:42 AM
Crysis450's Avatar
Any ideas why it still reads -38
Old Sep 25, 2018 | 07:33 PM
Crysis450's Avatar
hsiriyob
Jun 7, 2014 07:10 AM
2001CamaroGuy
Jan 20, 2013 04:42 PM
Predator
Jun 27, 2007 07:57 AM
TURBO8
Feb 11, 2007 05:17 PM
Wilde Racing
Feb 7, 2006 03:55 PM
