Trans Temp Guage vs. Trans Temp PID
Old Jun 25, 2007 | 05:16 AM
Predator's Avatar
Question Trans Temp Guage vs. Trans Temp PID
Fellas, I'm looking to get a tranny cooler for my TBSS, and I want to be able to monitor the tranny temp. I could install a tranny temp gauge, but what about monitoring the tranny temp with something like an Aerotech gauge that monitors tranny temp using the computer's PID?
Are the computer's PID readings as accurate as an installed tranny gauge? Thanks.
Old Jun 26, 2007 | 07:43 AM
I would have to say yes as the vehicle relys on that info to let it know if theres a problem. The tranny would have a built in sensor similar to an aftermarket one that you would install yourself.
Old Jun 26, 2007 | 08:09 AM
Phantom's Avatar
11 Second Club
the pid come from the same sensor the gauge in the cluster uses...which i think is in the pan. depending on where you would install the temp sending unit for a gauge your readings are gonna differ from the pid. in efi live, if my transmisson temp pid reads 130 my autometer gauge with sending unit installed in the pressure port will read 180 or so...
Old Jun 27, 2007 | 02:41 AM
Predator's Avatar
Thanks for the replies fellas.
That's interesting DD, so are you saying that your PID reading is 50 degrees too low, or is the autometer reading 50 degrees too high?
In either case it's troubling that the two readings are so far off.
Old Jun 27, 2007 | 05:29 AM
red53gmc's Avatar
What he means is that depending on where you place your temp sender, you'll likely get a different reading than the pcm temp gauge. The pan will always be cooler.
Old Jun 27, 2007 | 06:44 AM
Predator's Avatar
I see, got ya, so does that mean that the pcm reading is "correct," and the factory temp sensor is located ideally for the most useful readings? Thanks.
Old Jun 27, 2007 | 07:57 AM
Phantom's Avatar
11 Second Club
do a search on temp gauges...i forget the reason people like the reading to come from the pressure port
ferrellrooster
Mar 6, 2025 03:22 PM
Bumpers
Aug 4, 2024 09:44 PM
ullose272
Aug 5, 2016 02:05 PM
AkSSS
Mar 29, 2016 11:03 PM
GRRR65GTO
Aug 17, 2015 11:33 PM
