4L80e or FLP level 5?
Old Apr 25, 2005 | 09:28 AM
Wilde Racing's Avatar
How do I change this text
Question 4L80e or FLP level 5?
Well It's time for the trans, I've done a few searches in here, but can't find what I want. So any of you that have done the 4L80e swap or the FLP, if you could do it again wich would you do? Keep in mind I have to drive this thing EVERY day. I don't EVER take it ease on anything. I will beat this truck tell the Engine blows.LOL I just don't want to deal with anymore trans problems. also I plan on shooting alittle Nitrous some-time this year and would like to see 500+ at the wheels, all the time.
If I do go with the FLP I'll get a Denny's Diveshaft.
The speed Engineering drive shaft is guaranteed up to 800 hp.
I'd like to find a wrecked 2500 with a 6.0, 4l80e, and trans temp in the gauge cluster, is that a good idea? If so Where sould I look for one?
And as always, cost is a concern.
Please let me know what you think I should do, thanks for reading.
Old Apr 25, 2005 | 10:27 AM
Leroy_454's Avatar
I would do the 80E. You will notice it using up a little more power over the 60E, but it is so much stonger to begin with.
Old Apr 25, 2005 | 10:47 AM
2bseen's Avatar
11 Second Truck Club
How much hp are you going to run? If it is less than 650rwhp I would go flp level 5 that is what I am running.
Old Apr 25, 2005 | 11:10 AM
I don't think I will stop until I see atleast 500 hp at the wheels. Then alittle nos? so I think alittle under 650 would be safe.
Old Apr 25, 2005 | 11:23 AM
F8L Z71's Avatar
On a heavy turbocharged truck I htink the 80E is a good choice due to the high 1st gear. It will help you build boost faster Plus the gear spacing is superior anyway.
I think the FLP is a great trans but I wouldn't spend the gobs of money on a built 60E. If you're gonna do anything spend money on a built 80E and do it the right way.. ONCE! Hahaha
Old Apr 25, 2005 | 11:48 AM
so a 4l80e F8L? What should be done to the trans to make sure it will hold up?
Old Apr 25, 2005 | 11:51 AM
F8L Z71's Avatar
Please don't take my advice as the end all be all as I am only just now doing a similar swap. I have burnt up too many 60Es to trust them anymore. Plus after talking with Chuck he said he doesn't think a 60E would hold up to a 5000lb truck with 500+rwhp. I just didn't want to take any chances.
Old Apr 25, 2005 | 11:58 AM
Well I don't want to take any chances ether. I think I could do a 4L80e swap cheaper than the flp. but what should I look for in a 4l80e? will a bone stock one hold up?
Old Apr 25, 2005 | 12:35 PM
I also heard Parish8 complain about first gear of the 4l80e, saying that it is to high unless you have a ton of torque. Will I have enough torque to over come the high first gear?
Old Apr 25, 2005 | 01:36 PM
Also if anyone can recomened a Torque converter stall, that would be helpful. I was thinking around a 2500????
