4L60-E HD?
Old Sep 18, 2002 | 09:14 AM
Scream's Avatar
MOOBIES Moderator
Default 4L60-E HD?
Just found this in a press release from Cadillac:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
heavy-duty Hydra-Matic transmission
To handle the additional power of the Escalade's V8, the ESV employs a new Hydra-Matic 4L60-E electronically controlled four-speed automatic transmission with overdrive. This heavy-duty version of GM's smooth-shifting workhorse features a wide variety of internal enhancements to improve both torque capacity and durability.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Any idea on what makes the tranny "heavy duty?" Seems like that is the weakest link in our drivetrains...
<small>[ September 18, 2002, 09:15 AM: Message edited by: Scream ]</small>
Old Sep 18, 2002 | 01:31 PM
Scream's Avatar
MOOBIES Moderator
Default Re: 4L60-E HD?
hmmm, hadn't heard of the 4L65E designation...the Caddy website calls it a 4L60-E HD.
http://cadillac.com/cadillacjsp/mode...lade/spec.html
Scream's Avatar
MOOBIES Moderator
Thanks for the info, btw!
Old Sep 18, 2002 | 09:58 PM
GTO Forum Director
Are you sure it isn't 4L80E and 4L85E? Those are Hydra-matic's heaviest duty transmissions before stepping up to the Allison.
Old Sep 18, 2002 | 10:15 PM
RED2K's Avatar
I know Jet makes a rebuild kit for the 4L60. It is suppose to be stronger. Just read about it but I dont know first hand.
<small>[ September 18, 2002, 10:15 PM: Message edited by: RED2K ]</small>
Old Sep 19, 2002 | 12:59 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
They're calling it the 4L65E.
Compared to the 4L60-E, it has:
Five pinions in the input and reaction gearsets for 20 percent more torque capacity
New aluminum construction bushings in the stator shaft, providing higher torque capacity in a lighter-weight design
An extra clutch plate in the third and fourth gear clutch (7 vs. 6) for added capacity
A new induction heat treating process for the turbine shaft to improve durability
Improved strength at the lubrication holes for greater durability
Larger diameter clutch rollers in the (low/reverse) roller clutch assembly
Induction-hardened splines on the stator shaft for more durability and strength.
Old Sep 19, 2002 | 07:58 AM
Scream's Avatar
MOOBIES Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CMNTMXR57:
<strong>Are you sure it isn't 4L80E and 4L85E? Those are Hydra-matic's heaviest duty transmissions before stepping up to the Allison.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">According to Caddy's website, it's called the 4L60-E HD.
Old Sep 19, 2002 | 08:34 AM
red53gmc's Avatar
It is the 4L65E, though. The Escalade, I think Denali, and the new SS has it (for the extra HP and TQ)
Old Sep 19, 2002 | 08:46 AM
Neil 6.0's Avatar
True. I wish that GM would make up their mind about what they want to call it because they call it the 4L65E in their Hummer H2 & Denali info sites.
Denali
H2
The GM Powertrain site even has it and the 4L85E listed:
GM powertrain
Old Sep 19, 2002 | 10:16 AM
GTO Forum Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Scream:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CMNTMXR57:
<strong>Are you sure it isn't 4L80E and 4L85E? Those are Hydra-matic's heaviest duty transmissions before stepping up to the Allison.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">According to Caddy's website, it's called the 4L60-E HD.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yea, I guess I'm just as confused. Some call it one thing, I simply call it a 4L80/85E. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Chevy II
Feb 14, 2013 06:19 PM
vigil
Aug 7, 2009 05:06 PM
BlownChevy
13
Apr 30, 2004 12:14 PM
RobZ71LM7
Apr 12, 2002 12:49 AM
